Old February 4th, 2018, 06:16   #16
TDITim83
TDITim83's Avatar
I am needing to look into running a 2.5" pipe for exhaust.....first were do i get a 2.5" flange for coming off the turbo? Second, how do I get a Cat the will work for my car? Or should I gut the cat? I am wanting the car to stay quiet and still have plenty of air flow, I will get rid of stock silencer and exhaust. Would like to replace it with something that you can hear a small growl maybe. Though I do not want it loud and absolutely hate a droning noise
TDITim83 is offline   Reply With Quote
Old February 4th, 2018, 07:07   #17
john.jackson9213
TDI(s): 1996 B4V
You are running the stock turbo at stock boost with stock factory tune???
Based on my 11 years playing with the B4V: A 2.5 inch down pipe will do nothing for you at all. The stock turbo does not need a 2.5 inch down pipe. Even with bigger nozzles and a tune up to 18-20 psi of boost. Been there, done that on the dyno.
The stock turbo simply is very small and can not flow enough air to get more than a 40 to 45% increase in power over stock.
Changing your complete exhaust to bigger pipes can/will introduce "unpleasant" sounds to your cabin. No fun to ride from L.A. to Las Vegas in a car with that system.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old February 5th, 2018, 15:06   #18
TDITim83
TDITim83's Avatar
First of all....Thanks for the very good info on exhaust pipe john. I will probably just gut my cat and run a good flowing muffler out the back.
Second....Abacus....thanks a bunch man, I got the new Tensioner in and its installed correctly. I have not clue why I did it that way, my manual says differently. Life Saver
Back to my issue at hand....
I unhooked my exhaust and I feel not difference in power. Note....when in neutral and I tap the accelerator the RPM jumps up faster than with exhaust attached. So I do feel I have restriction. Though getting up to speed is about the same.
I am gonna run VAGCOM soon, what specs or readings should I look for that could be an issue. Assuming I throw no codes. If i have done an EGR delete, and haven't adjusted anything in VAGCOM would that be a possible issue for power?
Please read what I've done to the car so far, and ask further questions on parts if need be. I really want this car running awesome. No problem with idle and timing. But after acceleration it just kinda goes slow up to speed. I know the difference, I've driven two stock B4V's in the past year
Old February 6th, 2018, 08:27   #19
TDITim83
TDITim83's Avatar
Is there a way to tell if I'm getting enough fuel via VAG?
Old February 8th, 2018, 08:07   #20
TDITim83
TDITim83's Avatar
Default Update on findings.....
After replacing my timing belt tensioner I have ran VAGCOM.....timing is to advanced to plot. So I will resolve that. I also adjusted my settings to from 250 to 375 on the air intake side for the EGR setting.
I am wondering whats going on with my injectors....any input...or could they be off because of the advanced
Injection Quantity 6.4 mg/str
Mod. Piston Displ. 1.620v
MAF (Specified) 375.7 mg/str (originally was 250 I just changed)
MAF (actual) 455.5 mg/str
Intake Air Temp 42.3 C
Inj qty 0.0 mg/str
Inj qty 28.4 mg/str
Inj qty 28.2 mg/str
Injection Quantity CC Active 0.0 mg/str
Barometric Pressure 1031.7 mbar
Manifold 1040.4 mbar
I also threw some codes:
2 faults found
00550 - Start of Injection Regulation
17-00 - Control Difference
01242 - Output Stages in Control Module
27-10 - Implausible Signal - Intermittent
Readiness: N/A
Old February 9th, 2018, 06:19   #21
jdulle
I think you might have better power if you adjusted the Injection Quantity to 3 or 4 Mg/str. 6 might be enough to make less power.
jdulle is offline   Reply With Quote
Old February 9th, 2018, 13:37   #22
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk2's about 48mpg, mk3 ~43mpg thats @(near)80mph(-/+).
you have some injector info there. although its been a few weeks since ive had the VCDS screen up. the one reading you give there, inj qty 0.0mg/str. and you have 3 other inj qty readings there. do you have an inj timing reading. although you set the mechanical timing, then the injection (electronic) timing and the timing (and injection)becomes a standard, changing due to advancement across rpms. inj qty X.xmg/str as well changes with rpm, also load, depending on ecm and sensor readings.
did you clear the codes?
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
iluvmydiesels is offline   Reply With Quote
Old February 11th, 2018, 14:39   #23
TDITim83
TDITim83's Avatar
Default Resistor installed
I installed the resistor.....my check engine line went off. Also No power change.
How do I change the settings for Fuel Injectors.....what controls that
Im hearing my lifters taping. So I'm wondering if I have bad lifter springs. Any input?????
Old February 11th, 2018, 17:24   #24
TDITim83
TDITim83's Avatar
I heard when you clear codes form Auto Scan it doesn't actually clear them? Where do I go to clear the codes properly if this is the case?
Old February 15th, 2018, 13:03   #25
TDITim83
TDITim83's Avatar
I have tried another BK ECU and no change, I even tried mine in the other car. My ECU is fine. I changed the Turbo Boost EGR Valve, still low power. Vacuum lines are good. It idles so nice, but makes a valve ticking noise. Also revs like normal until you take off in gear and is just low powered. I am wondering if I have Valve Lash or worn guides.....anyone have any input
Old July 3rd, 2018, 07:03   #26
TDITim83
TDITim83's Avatar
So.....I have resolved the power issue. After 4 months of time off I got back into it. I swapped injectors with my AHU Jetta and boom. Now the Jetta is slow and the wagon has the power. I do hear a pinging though. I have decided to have the injectors rebuilt and pop tested. Once they return I will adjust fuel timing and I believe my issues are resolved. All the brakes are redone as well.
96 B4V Storm Grey 266K, 98 Jetta 258k
Old July 6th, 2018, 17:57   #27
TDITim83
TDITim83's Avatar
Also I had a sketchy rear hatch lock. I removed and modified so it would actually work properly. Added a small thin piece of aluminum with some Gorilla Epoxy and filed it down. Works great!!!! Rear bumper was also bumped into a pole and the hatch would rub when opening closing and rested on it. So I removed it and used a heat gun to shape it back down. Another great fix.
Last edited by TDITim83; July 6th, 2018 at 18:00. Reason: couldn't post pictures for some reason
Old July 7th, 2018, 04:52   #28
Steve Addy
TDI(s): 97 Mk3
FYI my 242k mile AHU in the B3V needed new exhaust valve guides when I pulled the cylinder head.
Steve
You didn't poison the coffee, did you? Not anymore than I usually do.
Low low end power until turbo kicks in and low again on highway. lirunaway VW MKIV-A4 TDIs (VE and PD) 9 February 28th, 2016 14:27
low power alh tdi. none of the normal issues but still low power Gerich@apex-tuning VW MKIV-A4 TDIs (VE and PD) 36 December 24th, 2015 21:44
Maybe it's just me... B4v low power? annieneff VW MKIII-A3/B4 TDIs 10 October 18th, 2015 12:29
low power continues on my B4V GeWilli VW MKIII-A3/B4 TDIs 27 January 24th, 2010 17:55
B4V Low Power Dilemma twentyeight TDI 101 14 January 13th, 2010 12:19
Page generated in 0.13392 seconds with 13 queries
[Output: 118.18 Kb. compressed to 99.39 Kb. by saving 18.79 Kb. (15.90%)]
