TOBarber
My 2000 Golf TDI no longer has AC. It was working marginally until last week when it was really hot. Now nothing. It doesn't come on at all. Both fans are running. I checked the power to the compressor and it just comes on and off immediately every second or so. I believe that means that it has no charge left.
I bought the Redtek kit at Canadian Tire and now I need basic instructions. There is a snap-on connection to the low pressure fitting on the AC. I did manage to get it on but it was not easy. The gauge still read zero psi. I took this to mean that the AC system was indeed empty. But when I opened up the can of coolant it went up to 100 psi quickly. From this I take it that the low pressure valve on the AC is not working and needs to be replaced. Or am I doing something totally wrong? I tried gently pushing on the pin in the AC valve but it didn't seem to want to budge. Is there still coolant in the system? It seems highly unlikely.
Any help is appreciated.
