Flooormatt
Mk4 tdi golf:
I recently installed pp520’s from KermaTDI. Had them pop tested and they worked fine. When I installed them the car started right up but idles with a little white smoke and even though it sounds ok I feel like t could idle a little better. THe really problem is when I try to rev it. It produces a lot of white smoke and runs really rough, at first I thought this was due to air in my fuel lines so I replaced the fuel filter and it fixed the air issue, however it still runs poorly. I think I may need to make some adjustments to the air/fuel ratio.
I wanted to get a tune for it, would this possibly fix the bad fuel/air ratio problem or is t something else?
Thanks to all those who can help out.
