vili19
Hi guys, searched the entire form found a couple posts but nothing concreate.
My dash has the bulb light on and rear light will not come on nor will the turn signal work. However the mirror and front turn signal works. Changed bulb no go..
Local guru told me something about the ground wire on these cars is a common issue to fix.
Anyone run into this issue or has a solution?
