tramic86
Hello everyone,
I'm hoping that someone could ease my mind a little bit. I bought my 06 TDI used last September with just over 160k on the computer. I had a few items that needed repair, so this is what I did in the year that I have had it:
-Had a fault code (can't remember the code) = Replaced ASV
-Replaced DMF (mis-diagnosis; had loud noise only in gear, turned out to be serp. belt tensioner and/or alt. pulley.)
-Replaced Serp Belt & Tensioner & Alt Pulley
-Added the missing belly pan to hopefully muffle the sound of the engine a bit
-Oil change (switched to Mobil 1 TDT -- Figured I was out of warranty, and I have heard good things about the TDT wear protection vs 505.01.) This was done maybe about 2 weeks ago)
-Diesel Purge (2 weeks ago)
Since I bought the car, it was noticeably 'knocky' when accelerating. I'm not sure if this is the nature of the BRM engine, or if I am missing something big. Even in Park or Neutral as well as in-gear, when RPM's increase, the loudness/speed of the 'knock' increases, until the next gear is hit and the RPM's drop again. It all seems to level off when I get to about 4th gear, but it may just be that the road noise is drowning out the knocking. At idle, it seemed to improve when I changed oil, but when accelerating it is about the same. I compared it today to a newer (2007-2010) Jetta that seemed to have a quieter, smoother idle. Even at acceleration, it had a smooth noise and not the knocking/clicking that mine makes.
Here is a YouTube video that is similar to the noise I am hearing: http://www.youtube.com/watch?v=3nkcxJ9bheI
The resemblance that I hear is that high 'click-click-click' type noise in the video as opposed to a smooth low rumble of a diesel.
They suggest possibly bad injectors, pistons or engine bearings in the comments and I'm really hoping that's not the case.
Before I bought the car (about 130k), there were a few items replaced/repaired such as the cam, and timing belt (along with idlers/pulleys, etc that go along with it) so I think I can eliminate worn cam as the culprit.
I'm hoping someone says its just the nature of the engine and I could ignore it. The fact that I don't have any fault codes and it actually has improved since I bought the car is a good sign, but I just want to make sure. If need be, I can record my own engine noise and upload it to YouTube for a more accurate diagnosis.
Thank you everyone in advance. I really appreciate any help that is provided!
MT
MT
