Old October 28th, 2018, 15:29   #3331
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Unless that 6 miles is at 100% throttle on a cold engine up a 10% grade both ways, you won't hurt anything .
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is online now   Reply With Quote
Old October 28th, 2018, 15:43   #3332
SilverSquirrel
Originally Posted by SilverSquirrel View Post
I just picked up a used Harbeck sailboat trailer. German, late 80's.
Seems very solid. Has a funky brake setup that i am going to ditch. I think it was used for a star class boat. I am putting my rhodes 19 on it. Its only going 6 miles, twice a year.
Boat and trailer weigh 1800 lbs. Is this too much for the tdi dsg sportwagen with a curt hitch?
Thanks. Anyone familiar with harbeck trailers? Where can i get parts in the usa if i need them?
SilverSquirrel is offline   Reply With Quote
Old October 29th, 2018, 14:26   #3333
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Diesel mower
Sent from my SM-G950U using Tapatalk
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old October 31st, 2018, 12:23   #3334
NarfBLAST
NarfBLAST's Avatar
Fuel Economy: 5.8 - 4.5 (40 - 52)
Originally Posted by coalminer16 View Post
Diesel mower
Sweet! Here is a picture of my gasoline powered D110 which regularly travels 60 miles or 100 km round trip to keep the lawn looking perfect out at my wife's grandfather's house. Long story. Also, never mind the giant magnet powered by the giant lemon on the roof racks. This was taken the day before I left for the Great Lakes Mistake LeMONS Rally.
- Paul
2001 VW Golf Naturally Aspirated Direct Injection Diesel 5MT 633,333 km
With 1.5" lift / Valeo G60/VR6 SMF /
Sprint 520's / RC3 / sweet turbo delete
The NARFmobile blog / push button ignition / thrustmaster shifter / http://youtube.com/narfblast
NarfBLAST is offline   Reply With Quote
Old November 16th, 2018, 15:38   #3335
FJ40Jim
FJ40Jim's Avatar
Fuel Economy: 44-52
We're thinking of replacing the ALH/5MT Golf with a 2011-14 JSW TDI/DSG. Can it handle towing the Scamp 13? Thinking of engine emission durability and auto tranny durability.
The Golf continues to tow very well, but at 280k it's starting to look tatty.
Thanks for any insights!
https://drive.google.com/file/d/1umN...ew?usp=sharing
Jim C
01 Golf GLS TDI 5M RC2/3 racepipe Sprint520 VDOgauges 215/55ZR16 hitch mufflerectomy yadda
12 JSW TDI DSG. Stock for now...
FJ40Jim is offline   Reply With Quote
Old November 16th, 2018, 17:59   #3336
Fix_Until_Broke
I'd think that towing would help all the emissions equipment live longer - EGT's are naturally higher when towing so it does not have to regen as much since there's enough heat in the exhaust to do it "naturally"?
Couldn't say on the DSG and towing. Guessing again that as long as it's not constantly shifting back/forth under high load it would be just fine?
I'm really speaking out of turn here as I'm still driving an ALH/6MT
Old November 17th, 2018, 06:40   #3337
jason_
Dsg is a brute. Malone tune mentions Hydraulic pressure modifications for the clamp force.
I plan to delete and tune both. Let that turbine free wheel!
Sent from my 2PS64 using Tapatalk
jason_ is offline   Reply With Quote
Old November 18th, 2018, 08:10   #3338
dremd
dremd's Avatar
Once I decided to turn in my DSG car I started abusing it heavily. The only thing it hiccuped at was trying to push a parked Prius (parking brake on)out of the way. The DSG would push for about 10 seconds then stop and allow you to retry. I towed some heavy stuff, and gave 0 craps. Granted it was only 15K miles.
Tesla Model S P85
03 Silver Premium Jetta Wagon ALH + 6speed MT
2013 Nissan LEAF Totaled
2006 Sprinter
2014 JSW (Went back to VW)
dremd is offline   Reply With Quote
Old November 19th, 2018, 06:36   #3339
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
I'm not sure when VW started saying don't tow with the dsg, but for my 10, it says it's capable of 1500 pounds. IIRC, the European rating was 1500kg or 3300 pounds. If you're not having issues with the ALH, I think you'll be fine with more power and the dsg.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old December 2nd, 2018, 09:18   #3340
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Hello,
My daughter started as a General Service Technician at a local auto shop a few months ago. I bought her this roller cart about two months ago:
I outfitted her with some tools, too. She has bought more tools and quickly outgrew the cart. So I got her something larger from Home Depot online. It arrived crated and needed some minor assembly:
Working alone with this 380-lb crate, there was no way I was going to completely unload it to install the casters. So I had to get innovative. My driveway is sloped, so I needed to raise the rear end up so I could slide the cargo rearward. My clutch did NOT like this maneuver...
I used a series of sliding and jacking maneuvers to get the casters mounted...
Then I had to lift the end so I could get ramps under the casters...
I used a winch to pull the cabinet into transport position...
My daughter managed to transfer some tools to the cabinet and was putting it to good use by the end of her work day.
Scott
| .M y . S t a g e . 2 . G T I . |
| Facebook | YouTube | Fuelly |
Stealth TDI is offline   Reply With Quote
Old December 17th, 2018, 08:30   #3341
casioqv
Originally Posted by phantom1260 View Post
What's the normal coolant temp for when you're towing.
IMO it should be impossible to exceed 100C, or else you have some components not in top shape. I can climb a long steep grade at full throttle with the A/C on and a trailer, and not get over 100C (usually only 95C max) in my '01 TDI golf. If you are getting higher temps I'd check that both fans work, and if so replace the radiator and thermostat.
2001 Golf TDI - 02m 6 speed swap; +ASR/EDL; panzer plate
2016 e-Golf
casioqv is offline   Reply With Quote
Old December 17th, 2018, 08:36   #3342
casioqv
Originally Posted by dieseldriver604 View Post
Hi, just wondering how you're getting along with the 2'' receiver from Tesla? i was inspired by your post and have found one. Planning on this set up for my mk6 Golf. Would be great to hear about your experience with it so far. Thanks.
I am really happy with the 2" tesla receiver, it's really a proper 2" hitch solution without any custom parts. I've done a few long trips towing my sailboat with it since the install. A huge advantage is that I can get the ball height just right for different trailers.
I found it pretty easy to get also, since most model X cars come with them, but the model X really doesn't work well for towing (kills the range), so people don't use them.
2016 e-Golf
Old December 17th, 2018, 08:39   #3343
Lightflyer1
Lightflyer1's Avatar
The newer cars are different than yours. They seem to have higher temps than the older cars by some degree. My old 2013 Passat tdi and now my 2015 Beetle tdi run around +/- 203F on a normal basis. Others have reported running hotter temps when towing of around +/- 230F.
Old December 18th, 2018, 08:00   #3344
casioqv
I wonder what the reason for that is, and if it can be "fixed." Maybe they just have a higher thermostat setting to reduce emissions or increase efficiency?
Keeping a water cooled engine under 100C at any speed with 100% sustained load is a recommended spec I got from an old mechanical engineering textbook, which also makes a lot of sense to me, as it guarantees you won't boil over even if you need to run the system unpressurized with plain water in an emergency (e.g. due to a leaking radiator). Admittedly, very few consumer grade diesels can do this, but the A4/MKIV/ALH TDIs definitely can, and it makes towing less stressful (for me and the car).
2016 e-Golf
Old December 18th, 2018, 08:03   #3345
Lightflyer1
IIRC the engine/emissions is more efficient at higher temps.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.19884 seconds with 10 queries
[Output: 140.77 Kb. compressed to 118.87 Kb. by saving 21.89 Kb. (15.55%)]
