Old November 5th, 2018, 18:44   #1
laminated
Default vag mod worth doing
was in a 15 with this mod, makes that flat spot disappear in the accelerator
[Direct Acceleration - Throttle response]
With this mod, you can change the behavior of the accelerator. Option B provides a more linear acceleration without sudden deliveries.
1 - Module 44 - Power steering. then in security box enter Code (19249) after that
2 - Adaptation
3 - Select - switching driving profile
Choices :
A - Gradual, controlled by time
B - Directly controlled threshold value
laminated is offline   Reply With Quote
Old November 5th, 2018, 19:58   #2
Grigg3
This made my manual drive more predictable, when shifting can now manipulate the throttle, matching speeds for smooth gear changes like in the older cars. Like it should be.
I wondered if MPG would suffer and seems to not have bothered it at all, at least with my driving style.
05 Jetta wagon, 15 Golf wagon
Grigg3 is offline   Reply With Quote
Old November 6th, 2018, 05:53   #3
740GLE
best 10 minutes with a laptop . . . ever
Old November 6th, 2018, 06:20   #4
oilhammer's Avatar
Fuel Economy: fantastic
I agree, it makes a noticeable difference.
www.cardocautomotive.com
Old November 6th, 2018, 07:06   #5
sands80
Fuel Economy: 46.4mpg
I've heard about this mod - just curious- why does this setting come standard from VW - what is the purpose of a non-linear throttle for the everyday driver?
I had assumed that the speed and the responsiveness of the TDI was slow (because it was a diesel).
sands80 is offline   Reply With Quote
Old November 6th, 2018, 07:49   #6
oilhammer's Avatar
Probably because they do not want unintended wheelspin on a small FWD car with a small V8's worth of torque on tap not much off idle.
There are LOTS of modern cars that nerf the output of the engine at lower speeds and/or in lower gears.
This is why my old VAG diesels were so fantastic in the snow, even just being FWD with no locking diff or traction control of any kind. With only 52hp and around 85tq, it simply didn't have the power to spin the tires, even in snow. It just slugged right on through like a yak.
Old November 8th, 2018, 12:27   #7
mopower
TDI(s): 15 GSW
I'm adding this to my list of things to try next time I have access to the vagcom!
mopower is offline   Reply With Quote
Old November 8th, 2018, 13:51   #8
The Tortoise
Throttle Response + Starting Vibrations + Dynamic steering are the holy trinity of Mk7 Vag-Com/OBD11 changes.
The Tortoise is offline   Reply With Quote
Old November 9th, 2018, 05:20   #9
740GLE
My only guess for that extra .5MPG by smoothing out response. EPA numbers are key.
A Mod worth doing SVTWEB VW B5 Passat TDIs 16 September 23rd, 2009 12:36
Air Intake Mod - worth it? NewTdi TDI Power Enhancements 5 November 28th, 2004 12:58
How do you make VAG-1552 do VAG-COM adaptation mod triggerman VW MKIV-A4 TDIs (VE and PD) 4 October 17th, 2003 07:02
is vag com worth it A4tdi110 TDI 101 9 April 9th, 2003 19:44
VNT mod is it worth it?? Rick TDI Power Enhancements 22 February 23rd, 2000 16:44
Page generated in 0.12706 seconds with 12 queries
[Output: 89.91 Kb. compressed to 76.79 Kb. by saving 13.12 Kb. (14.59%)]
