So after reading for over an hour, I am confused.
The limp mode thread says that the actuator should start to move at 3-4Hg and bottom out at 18Hg. But it also says that a vacuum leak can cause overboost.
I have overboost. The turbo appears to be stuck in full boost. The ECU is limiting fuel to keep it under control.
What is the relaxed, no vacuum state of the turbo actuator? Full boost or no boost?
