redscare
Hi, After reading a dozen threads, I just wanted a bit of clarification.
Car is a 99.5 tdi golf manual 250K
I am in the process of starting to change the timing belt. I read the how to a few times over.
My issues is when the cam lock is installed, my ip slot is half out of the window and my crank tdc mark is 'almost' not visible.
pics of the crank markings
way off to the right.
pics of the cam
pics of the ip window
I was planning on removing the cam locking plate
breaking the cam sprocket loose
reinstall cam lock plate, so the cam stays in the right spot
rotating crank over till marks line up
install crank locking plate, then follow the rest of the TB procedure.
Now, my question is if my timing was that far off, could this lead to drivability issues later. I had a reoccurring CEL that said the start of injection pump timing was off. It would pop up when accelerating with a load. I would lose power until i lifted the throttle, then reapplied the throttle. Annoying while trying to drive up a hill. I would be lifting and applying the throttle all the way up every 10-15 seconds...
My timing belt was changed by a shop that no longer exists, so asking them how they set it or if they messed up is no longer an option. Also the same shop failed to torque or reused the old engine mount bolts, as one sheared off, breaking the ear off the block and break the other bolts, so the whole engine fell sideways in the compartment.
They "fixed" it by replace two of the three bolts, but never mentioned the issue about the block to me. I only noticed when i went to remove the engine mount bolt that did not exist.
So it comes as no surprise that the timing is a bit off as well.
pics of the cam
