Diesel_Power
- Joined
- Nov 28, 2006
- Location
- Canada
Hello,
I think the right rear axle is bent since when I turn the hub with the rotor on it the rotor seems warped. I ordered new rotors as I thought they were the problem at first but after installing the new rotor it does the same thing. No noise from the bearings just the warp issue. So this must be the axle stub needs replacing. Right?
Is this quite difficult?
Should I buy a used axle/bearing hub complete from a wrecker?
It is a 2001 Jetta TDI.
Thanks and I really think this is a Great Forum.
