ok good observation Frank M! last time I did the belt a few years back, I took the cam sprocket off. again, nothing was locked in place last time either. the car was also not vag-com'd last time after the TB change. I don't remember why I took it off... I just did. also, I would have thought the cam sprocket would be keyway'd. I'm clueless as to why it's not. cam timing on an interference engine is nothing to play with, but who knows maybe it's a diesel thing I don't understand. anyways, would cam timing being retarded affect how the fueling looks on vag-com. do you think I should dick around with it, or well enough alone? or do I fix it by advancing the injection pump. the injection pump has never been touched... it's exactly how it left the factory. I can ask my dad to make me a cam locking tool, I have a neat design in mind... it wouldn't be THAT difficult to do.
also, when a gas engine runs lean, EGTs skyrocket and the engine pings (detonates).... does diesel do the same? I'm assuming being under the recommended area, it means I'm running lean. am I risking melting the pistons? do diesels detonate?
excellent advice everyone!!! if possible I would totally rather just advance the injection pump (since it doesn't involve removing the TB again - I just did it twice over the last week). however, if necessary, I don't mind fixing the cam timing to not be a degree or two out, but that'll wait till springtime if that's what it's gonna take.
