jimnms
Full Story Here
General Motors, a company notorious for allegedly conspiring with Big Oil and others to "kill the electric car," is about to roll out a unique, fuel-efficient sedan that could redefine electric vehicles.
The new Chevrolet Volt, which premieres Sunday at the North American International Auto Show in Detroit, is a new spin on hybrids. The Volt runs exclusively on battery power, but a gas-fueled engine onboard runs the motor and recharges the batteries when they run low.
The sedan uses liquid fuel in the form of gasoline, ethanol or diesel to power the 3-cylinder generator, extending the driving range. Its engine recharges the Volt's batteries in approximately 30 minutes, says GM.
It can go 600 miles or more before needing refueling or recharging, according to GM, and the batteries should last for about 40 miles without recharging. To reduce fuel consumption, drivers can plug the Volt into a standard 110-volt electrical outlet to recharge the batteries in approximately six hours.
Wow, 600 miles between refueling and 50 mpg, if only we had a car out now that could do that.The electricity-generation system can be modified to run on gasoline, ethanol, diesel, biodiesel or even a fuel cell in the future, he said.
The Volt has the same operating characteristics as plug-in hybrid vehicles currently being developed (primary battery power supplemented by burning fuel), but hybrids differ because they can simultaneously generate power from a combustion engine and electricity.
Substituting an electric generator for plug-in hybrids' internal-combustion engine simplifies the engineering process because it doesn't require managing multiple power sources, according to Posawatz, and it cuts costs by eliminating a mechanical transmission.
While a hybrid drive train is more energy efficient than the Volt's, the new car will get about 50 mpg when the generator is on.
At $10,000 for the batteries, I wonder what one can expect the "lifetime" of the vehicle to be?Though the new car uses a different technology, the batteries in the Volt perform nearly identically to those in the EV1, which GM developed in the 1990s. Posawatz said the Volt's lithium-ion batteries can store about the same amount of power (16 kilowatt-hours) and provide nearly the same vehicle range (40 miles or more) as the EV1's lead-acid batteries. However, the lithium-ion batteries, located under the Volt's chassis and are about a third the size of the EV1's, should last the vehicle's lifetime.
GM has not stated a target price for the Volt, but the lithium-ion batteries alone would cost upward of $10,000 today, Posawatz said.
