Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old February 25th, 2018, 07:01   #1
jeffreyjackson
Default Boost Gauges
Anyone ever installed boost gauges on a v10?
jeffreyjackson is offline   Reply With Quote
Old February 26th, 2018, 18:46   #2
Fourdiesel
Fuel Economy: ~53 mpg on Golf (sold)
Shouldn't need to - I believe you can use Scangage or equivalent.
2004 Touareg V10 TDI Colorado Red
Blk 2000 Golf 5spd 2-dr (now grandsons)
Sand Biege 2008 Mercedes GL320 CDI (wife's)
'83 Mitsubishi 4X4 PU(2.3L turbodiesel)
'85 U1700 UNIMOG ["I DO understand - its a UNIMOG thing"]
Fourdiesel is offline   Reply With Quote
Old March 1st, 2018, 14:17   #3
Nevada_TDI
Or possibly Torque Pro for Android?
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, Stage 4 Custom TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 12th, 2018, 17:41   #4
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Technically you'd need TWO boost gauges. The V10 is very literally set up like two separate engines sharing a crankshaft, each with its own turbo, own intake manifold and own intercooler system as well as own engine computer...
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
boost gauges openthrottletroy VW MKV-A5 Golf/Jettas 2 March 5th, 2016 17:57
Boost gauges tmarion VW MKIV-A4 TDIs (VE and PD) 4 January 22nd, 2012 19:17
Boost Gauges tdikb TDI Power Enhancements 7 February 17th, 2008 13:37
****Those with Boost Gauges look here**** red golf tdi TDI Power Enhancements 45 August 25th, 2004 14:05
Boost gauges and the like goro VW MKIV-A4 TDIs (VE and PD) 0 November 24th, 2003 15:02
Page generated in 0.08500 seconds with 11 queries
[Output: 62.76 Kb. compressed to 56.11 Kb. by saving 6.65 Kb. (10.60%)]
