Old December 15th, 2015, 16:25   #1
Redman84
TDI(s): 2003 Jetta
Default Clean or replace turbo?
I'm near 265k on original turbo. Throwing the stupid intermittent over boost code. Have all new vac lines and the VNT actuator tested ok w mity vac. Still need to check the n75 w VCDS but if that tests out well should I even bother with cleaning it or just get a new one?
Still learning,
Jacob
2003 Jetta Wagon GLS TDI 5 spd 250k
2003 Jetta GLS TDI 5 spd 315k(sold)
1996 F250 7.3L Powerstroke 5 spd 255k
Redman84 is offline   Reply With Quote
Old December 15th, 2015, 16:28   #2
jettawreck
jettawreck's Avatar
If your oil consumption is normal/not increasing and after a inspection of the turbo shaft play determines its present state, then decide.
2004 Cadillac SLS (wife's)
Old December 15th, 2015, 17:02   #3
Redman84
TDI(s): 2003 Jetta
Is there enough room to check shaft play w it still in the car?
Still learning,
Jacob
Old December 15th, 2015, 18:00   #4
AndyBees
AndyBees's Avatar
Default Shaft play
Yep! Just remove the hose on the suction side of the Turbo and stick your finger in there and feel the end of the shaft .... jiggle it up and down. There will be some up and down (side-ways) movement. There should be virtually zero in and out movement. You will find some oil inside there too. What counts is how much oil you have to add during the 10,000 mile change interval.
The clamp on the hose is in a tight place, but it can be removed!
The Turbo on my 2000 Jetta has 354k miles on it and has never been off or cleaned..... works great! I have to add about 1/2 quart of oil by the end of the oil change interval.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is online now   Reply With Quote
Old December 15th, 2015, 18:01   #5
Jake_S
Jake_S's Avatar
Yup. Remove the outlet pipe, and check for excessive axial (in and out) movement of the turbine.
Jake
05 Jetta Wagon, 09A, EGR delete, k0mpressed tune, VNT17
84 Chevy K20, 350/SM465/NP208
Specialized StumpJumper FSR
2012 GT Transeo 2.0 w/ carbon fork
KHS Flite 300 w/ Ultegra drivetrain
Jake_S is offline   Reply With Quote
Old December 15th, 2015, 18:44   #6
[486]
TDI(s): 02 golf ALH
Jake
in not out
[486] is offline   Reply With Quote
Old December 15th, 2015, 19:08   #7
AndyBees
AndyBees's Avatar
If you can push the shaft in, you should be able to pull it out. Thus, you are looking for the amount of "in and out" movement. ...... which should be virtually zero!
Old December 15th, 2015, 19:11   #8
[486]
TDI(s): 02 golf ALH
if you can get your fingers on the compressor wheel through the compressor outlet you've got better fingers than me (winky emoticon)
Old December 16th, 2015, 03:26   #9
AndyBees
AndyBees's Avatar
Fingers on the "compressor wheel" isn't necessary, and, no doubt impossible as per the circumstances being discussed in this Thread.
Through the Compressor "inlet," push on the end of the shaft, then pull out on it, either with your fingers or needle nose pliers.
Back to the OPs original question, the issue may be something besides a "dirty" Turbo as you've already suggested. I'd eliminate those things before attempting to "clean" the Turbo.
There are two options to clean the Turbo, do the chemical clean (huge long Thread on the pros and cons) or remove the Turbo and disassemble on a work bench. Complete disassembly is not recommended (taking out the Turbine Shaft), as you run the risk of getting the assembly out of balance.
Check out my photo gallery for Turbo pics relating to cleaning.
http://pics.tdiclub.com/showgallery.php?cat=5302
Old December 16th, 2015, 05:35   #10
Rembrant
Rembrant's Avatar
Fuel Economy: 50 MPG.
I just cleaned a VNT-15 turbo on the bench last week...and I was surprised at how well it worked. I have to admit...I didn't read the huge long thread, so I don't know what the "cons" are, and maybe I don't want to know.
Although the VNT actuator was rusted out, it still held vacuum, but the VNT lever stopped at about 2/3 travel.
I put the nozzle and straw from a can of Brake cleaner on a can of oven cleaner so that I could reach as far as possible in behind the exhaust turbine wheel. I had a couple cleaning sessions over a couple evenings, and would work the VNT lever with my fingers while the turbo soaked. I even filled the CHRA oil cavity with fresh engine oil so that nothing would get in there while cleaning.
The VNT now has full travel and the operation is smooth.
I would definitely clean and inspect an old turbo before buying a new one...they are expensive after all.
2006 White Jetta BRM TDI 5spd w/Black Leather.
2011 Black Lexus IS250 AWD. My wife's, the high roller.
1984 Ford F150 Stepside project. Old school 3 on the tree.
Rembrant is offline   Reply With Quote
Old December 16th, 2015, 09:23   #11
[486]
TDI(s): 02 golf ALH
well that's what I get for trying to be jokingly pedantic
Old December 16th, 2015, 09:26   #12
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
For the cost of a proper replacement, definitely consider taking it to the bench and cleaning it.
Old December 16th, 2015, 10:47   #13
Redman84
TDI(s): 2003 Jetta
Lots of good replies. Thank you all. My oil consumption has gotten up to +- 1 qt over 10k miles with no appreciable leaks(small occasional drip originating at valve cover). I'll test the N75 hopefully this evening and also try and check the shaft play too.
Still learning,
Jacob
Old December 16th, 2015, 11:02   #14
vtpsd
Fuel Economy: 45mpg avg
cleaning the turbo isnt too bad, i would try that. I was able to get mine spotless inside with oven cleaner. They work effortlessly when properly cleaned.
current: 03 jetta wagon (pp520, malone stg3, straight pipe), ford tractor with saab turbo, Snarling Audi 90q AHU swap (holset he211w, 32psi, race 520's)
past:11 second audi 90 20vt monster, 20vt swapped audi 90 winter beater, 10vt swapped 4kq with efi and many many other 5 cylinder audis, and a few 1.8tq's
vtpsd is offline   Reply With Quote
Old December 16th, 2015, 13:33   #15
[486]
TDI(s): 02 golf ALH
I used 'dry moly' (molybdenum disulphide) spray on mine when I put it back together. ZEP makes it, it's like graphite lube but fancy and space age. There was some rust in there, so I figured either that or rustoleum barbecue grill paint.
VNT 15 Turbo - Clean or Replace? BuffaloDiesel VW MKIV-A4 TDIs (VE and PD) 5 August 15th, 2015 12:09
Replace turbo or replace car ('03 jetta tdi)? coolbean1000 TDI 101 27 April 22nd, 2012 15:24
Labor hours to clean intake manifold and replace turbo? 03_01_TDI VW MKIV-A4 TDIs (VE and PD) 1 January 5th, 2008 12:54
Injectors.... clean or replace? Snowman VW MKIV-A4 TDIs (VE and PD) 21 March 18th, 2006 06:48
K&N - clean or replace? mijesor TDI 101 6 December 4th, 2003 16:40
Page generated in 0.16010 seconds with 11 queries
[Output: 132.73 Kb. compressed to 110.94 Kb. by saving 21.79 Kb. (16.41%)]
