Old March 13th, 2018, 02:36   #31
bwk9087
TDI(s): 2003 1.9 ALH
Originally Posted by evguy1 View Post
I also knocked the big check ball out of the tank inlet. It may not have been one of my problems but anything that will restrict the diesel and cause it to foam is bad.
I think in the end the 1 1/2" fill and new vent were the solution.
I like your vent fitting, what is it?
The vent fitting is a standard tipover valve, with vent line, bought at most any speed shop, I got it at speedway motors. I will keep the big check ball for now, as I will be offroading on occasion, also, and might need some of these safeties.
bwk9087 is offline   Reply With Quote
Old March 13th, 2018, 08:39   #32
samuraitd
samuraitd's Avatar
I like your gauges. Care to share a little more info on how you built them?
1986 Samurai AHU MTDI swapped, stretched, built
samuraitd is offline   Reply With Quote
Old March 13th, 2018, 09:15   #33
bwk9087
http://forums.tdiclub.com/showthread...+guages&page=3
this is where I started my guage journey, right from this forum. Each guage is run by a single arduino nano. You don't have to do it this way, I like it for simplicity, if 1 component fails, the others keep working, like a standard guage. The displays I use are a 1.8" tft screen that interfaces to the arduinos. I have had this done for some time, so I don't remember everything I did off the top of my head, except for the egt uses a max6675 interface board, and a k type thermocouple that is 5" long, long enough to get into main exhaust path from egr port. The oil temp is using a standard GM coolant sensor 12146312,and the boost is using mpx5700gp sensor, the oil pressure I am using a generic pressure sensor off ebay, 0-500 psi, I think. I will be using the same gm sensor to control the output to the coolant glow plugs also.
Old March 13th, 2018, 16:37   #34
samuraitd
samuraitd's Avatar
Awesome! I'll do some reading up on it!
Old March 14th, 2018, 03:27   #35
RollingCoal11
TDI(s): 2006 Jetta
Fuel Economy: 43 with a 49 best
I found the late model JKU airbox has a better outlet angle for the turbo inlet and they are cheap when guys change to CAI. The stock airbox should flow lots for the TDI.
Were you able to keep all of your factory gauges to work? I would be interested in how you did that? I been looking at a JKU or a FJ40 conversion. I prefer the JKU for moving the family around.
Also if you turned up the BEW to 200hp range, how well it move with 35's or 37's with proper gearing.
Chris
Chris
2006 VW Jetta TDI 5 spd
1997 Dodge 3500 Crewcab 4wd. Lots of parts
1936 Chevy pickup 4bta cummins project.
RollingCoal11 is offline   Reply With Quote
Old March 15th, 2018, 12:08   #36
evguy1
I don't want to hijack this cool build thread.
Mine is here: http://forums.tdiclub.com/showthread...&highlight=JKU
On all the swaps I do I leave the original ECU in place to run the dash and other systems like ABS. So many systems are all interconnected on modern vehicles. If you remove one part of the system then often the other parts stop working as well.
I installed the oil pressure and water temp senders from the Jeep into the TDI and it all works. The tach also requires a cam sensor input but most often you can just take the crank sensor output, run it through a Digital Dakota box and its close enough to fire up the tach. It does not use the cam sensor to run the tach so it does not have to be accurate. I think it just uses the cam signal to confirm the engine is running??
I don't have the tach working on my JKU swap yet as I have not had the Jeep back long enough from my kid to install the DD box. ;>)
evguy1 is offline   Reply With Quote
Old March 15th, 2018, 12:44   #37
bwk9087
This is the way I am going also, so I should be able to report on this soon. I mounted the actual cam sensor, it was easy enough. We will see. I don't know if I consider it hijacking, when I am gaining knowledge from you, that helps me out!
2007 Jeep JKU w/ 2003 ALH. 11mm pump, 520 race injectors, pd150 intake, GTB1756VK, EGR delete, ARP Head studs, Malone Stage 5 tune, SPEC Stage 2 clutch.
My Build: http://forums.tdiclub.com/showthread.php?t=486726
Old March 16th, 2018, 09:44   #38
evguy1
I'm interested if that does it. I'm just assuming that's the only thing stopping my tach from working at this point.
I did something similar on a Ranger swap when I needed a crank signal to shift the automatic. I did not have the original crank sprocket and made one out of a chain sprocket with the correct number of teeth and just milled the tops of the teeth flat and removed two teeth for the TDC signal.
Its bolted to the PS pump pulley.
Yes there is actually quite a bit of room between the crank pulley and the sensor. ;>)
Old March 16th, 2018, 09:48   #39
bwk9087
Nice, that is what I have for a backup, a tone ring from a camaro, I think it is, that I removed two teeth, and welded up two teeth to replicate the jeep ring.
Old March 16th, 2018, 15:05   #40
Hasenwerk
Hasenwerk's Avatar
Question: Why run a hall sensor like this for the tachometer signal? On the BEW/BHW T94/28 is the tachometer signal output.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 26th, 2018, 06:41   #41
bwk9087
got some things done, going good so far.
got coolant lines run, added coolant glow plugs inline with a coolant sensor for Arduino control. Factory jeep coolant sensor is on other hose.
downpipe and exhaust is all done.
map sensor bung welded on intercooler pipe.
Intercooler mounted, it is a 20 x 7 x 2.5 universal.
Old March 26th, 2018, 06:42   #42
bwk9087
front end back on
intake and intercooler piping done. Had to go back to fishbowl, since jeep overflow was in way of intercooler piping. N75 is on, and all vacuum plumbed.
was able to keep factory air filter setup, tight fit under it for the one intercooler pipe, but was able to maintain the 2.5" piping.
that is is for now.
Old March 26th, 2018, 18:21   #43
Motohead1
Lookin good. Where exactly is that map sensor in the intercooler piping? Interested to see how you like the GTB1756VK.
Dodge Dakota QC Tdi
Motohead1 is offline   Reply With Quote
Old March 27th, 2018, 08:34   #44
bwk9087
on the right (driver side) coming out of the intercooler. I don't have a pic of that yet.
Old March 27th, 2018, 17:07   #45
bwk9087
Default 2 small coolant hoses on back of head
I thought I had the coolant hoses figured out, but, I missed one, I took the small one to the top of the fishbowl, where does the one just below it go? the small one seems to be 1/4, and the other 5/16. I was going by this schematic.
2008 Jeep JKU / TDI swap evguy1 TDI Conversions 47 March 23rd, 2018 10:44
Diesel Jeep Wrangler Kriesel Non VW Group Diesels 0 February 11th, 2012 14:13
Jeep Wrangler Will Come in Diesel Form chewy Non VW Group Diesels 5 November 11th, 2009 04:08
Jeep Wrangler CRD? tditom Non VW Group Diesels 8 May 13th, 2009 19:00
TDI to Jeep Wrangler SpotsPhiLL TDI Conversions 3 August 3rd, 2008 16:14
Page generated in 0.19576 seconds with 13 queries
[Output: 138.65 Kb. compressed to 117.31 Kb. by saving 21.35 Kb. (15.40%)]
