topfrog007
2000 Jetta TDI - ABQ, NM - 5 Spd. Low Miles, Tons of Maintenance
Hi all,
Back in January I purchased this TDI in Florida, where it had spent all it's life.
I knew the car needed a new clutch as well as some other issues. (Turns out it would need a lot more than I thought!)
Entire engine replaced a month ago. Took a 2001 TDI (11MM) with 110,000 on it and put it in my car. I have paper (reciepts) and pictures to prove this.
Car starts and runs great, currently no issues.
Recent Maintenance:
* 10K < - Diesel Geek 100K Timing belt kit
* 5K < - New Clutch, pressure plate, flywheel - SMF VR6
* 1K < -New Slave Cylinder
* 1K < - Power steering fluid flush with CHF11F
* 1K < - Oil and filter change (Rotella T6, MANN filter)
* 1K < - New Fuel Filter
* 1K < - New Coolant Temp Sensor
* 1K < - New Glow Plug Harness
* 1K < - New driver side CV/Drive axle
* 1K < - Brake/Clutch fluid flushed and replaced.
* 1K < - New Mass Air Flow Sensor (MAF)
* 1K < - New Starter
* 1.5K < - New Front left wheel bearing
* Coolant Flush (G12)
* Tranmission fluid flush (Synchromesh)
* 11MM Injection pump
* Intake/EGR and Turbo were all taken off and cleaned thuroughly prior to install.
Body is in great shape, no rust, one or two minor dents. Some paint scratch/peeling.
Tires in good shape, 75% or more tread.
Forgot to mention that I have 8 Tires and 7 rims going with this car as well as a set of Bilstein TC suspension (not installed).
4 X 15" steel wheels + tired... 3 X Wolfsburg RX-II rims with 4 X 16" tires
Just to Recap. Body and transmission (5SPD) have 270,000 miles on them. Engine has 110,000 miles on it. Clutch has 5,000 miles on it.
Located in Albuquerque, New Mexico.
3,500.00
Call or text to 505-350-1521
More pictures here:
http://albuquerque.craigslist.org/cto/4539911909.html
Hi all,
Recent Maintenance:
3,500.00
More pictures here:
