Does anyone have the ALH Camshaft/Camshaft Journal wear limit specification. I'm mostly looking for the correct maximum wear limit specification for the clearance(space) found between the ALH Camshaft and the Camshaft Journal Caps.
Ok, here is some ALH Engine and Valve Train info to share. U can find info about the camshaft service inspection and repair information in both links. It also provides spec info not supplied by the MFG too. Although the link is to a Russian Server, it's in English, not Russian.
