[SIZE=-1]Not to argue with Mr. RC, here's what I dug up doing googles:
If you get the turbine too hot, it can damage the turbo. At 1270 degrees F, the tips of the turbine blades begin to glow. If you get them too hot, they'll straighten out or even melt and you'll ruin the turbo. The factory Garrett turbocharger will pull all day long at 1250 degrees, but in our opinion, 1270 degrees is the DO NOT EXCEED temp for sustained use. (I know we don't run Garret's, but it has to be similar technology with similar operating constraints...)
I can relate to the "heat of the battle" brain fade... I always tell myself during the first few laps of the day to take it easy. Cold brain, cold track, cold tires, CHILL!!! Then I get into it with another rider and it's all out... I almost had the rear tire come around on me one morning when I couldn't keep "it" in check...
[/SIZE]
