Parts Covered Under Extended Warranty
The entire exhaust after treatment system, including the Selective
Catalytic Reduction converter (SCR), Reducing Agent (AdBlue®)
Injector, other Diesel Exhaust Fluid (DEF) system components, Diesel
Particulate Filter (DPF) including Oxidation Catalytic Converter, the
exhaust flap, and all sensors and actuators;
The entire fuel system, including fuel pumps, high pressure fuel rail,
fuel injectors, vibration damper, pressure control valve, and all sensors and actuators;
The EGR system, including EGR valves, EGR cooler, EGR filter, EGR
temperature sensor, all related hoses and pipes, and all sensors and
actuators;
The charge air temperature sensor and air-mass sensor;
The turbocharger, including the turbocharger damper;
The glow plug;
The On-Board Diagnostic (OBD) system, any malfunctions detected
by the On-Board Diagnostic (OBD) system other than those related
to the transmission
Additionally, the engine long block warranty shall cover the engine
sub-assembly that consists of the assembled block, crankshaft, cylinder
head, camshaft, and valve train.
The extended emissions warranty includes parts, labor, and applicable
taxes. If the warranty service is scheduled to take longer than three
hours VW must provide a loaner vehicle. The extended emissions
warranty shall not void or supersede any existing warranty. Conflicts
concerning the warranty are to be resolved in favor of the consumer.
More information about your extended emissions warranty coverage is
available at
www.vwdiesellookup.com and in the customer letter we
sent to you previously.
10
Customer Notices
If you choose to keep your vehicle but decline the emissions
modification at this time, you should be aware that certain
emissions-related replacement and repair parts may at some point
no longer be available from Volkswagen. Accordingly, in the future,
if your unmodified vehicle requires maintenance and repairs of the
emissions system we may need to install parts associated with the
emissions modification, or, in some cases, install all aspects of the
emissions modification. You should not have any issues with the
ability of your vehicle to pass the inspection and maintenance test.
This may lead to changes to your vehicle’s operation or performance
resulting from those modifications as discussed in this booklet.
If the vehicle has been modified by the customer prior to receiving
the emissions modification in a manner that may yield a non-compliant
emissions system (for example, removal of a catalyst, installation of
parts that impact emissions or emissions-related parts, or modifications
to the ECU or computer software of the vehicle), Volkswagen may not
be able to perform the emissions modification until the customer
corrects such modification.
Transferability
This extended emissions warranty is fully transferable to subsequent
owners.
Warranty Notices
All normal warranty provisions remain in effect.
