2 problems
ballface
Northern Illinois
98 New Beetle
ok so I recently traded my Jetta for an NB and I have two problems that I have been working on that I could use some help with from the club
1. glow plugs. car is throwing glow plug CEL I think code p0380 from what I recall when scanning it the other day. I tested them tonight with a multimeter and from left to right they read: nothing, 1.0, 1.2, 1.0
first glow plug is obviously faulty and needs to be replaced but what would cause it to not read anything?
2. driver side door lock. the passenger door works perfectly fine; it locks and unlocks with the key and activates the alarm when locked. the driver side does not activate the alarm when locked with the key and will not turn to unlock. car did not come with a key fob so I cannot test if that will work and it is just the key cylinder that is faulty. has anyone else had this problem? I would like to fix it asap as I do not like leaving my doors unlocked nor do I want to have to go through the passenger door everytime I want to get into my car if I do lock them. sidenote: do not know if this is related, but I have noticed that the driver side window rolls up and down a little slower than the passenger side does.
steve6
Beaverton, ON
2003 jetta tdi
the glow plug could have been damaged when trying to be removed, they sometimes 'turn' within themselves(or within the main body), this could cause it to not have a good connection anymore.. hopefully it comes out easily enough. eg: http://forums.tdiclub.com/showthread.php?t=381282
the door locks have known 'cold solder' issues in early mkiv's and bad switches throughout all the years.. if 98 is correct you're probably suffering from cold solder issues, if you search around you can see pictures of this, it can be fixed if you know how to solder. It could be both , look at the 'stupid $3 door switch' thread as well.
JB05
Il.USA
Golf,2005,anthracite blue
the "nothing" reading should probably be rechecked. My faulty glow plug did have a higher than normal ohm reading.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Those are 2 common complaints.
Glow plugs are a simple repair, often at this age the harness may need replaced or re-built, they can get "crumbly".
The door switch needs the panel removed to get to it, in the mean time, never leave the key in the car with the doors closed, windows up, it can lock you out. Double tapping the unlock may be required before locking.
ballface
Northern Illinois
98 New Beetle
thanks for the input y'all, gonna order a full set of plugs tonight & just replace all of them and going to take the door apart this weekend to have a look at it
wonneber
Monroe, NY, USA
Spray them twice a day with PB Blaster or WD40 for a couple days.
I sprayed mine cold in the AM and hot getting home at night.
Mine came out real easy.
There's a torque spec NOT to exceed when loosening them or they may break off. :eek:
ballface
Northern Illinois
98 New Beetle
How many days should I do this and wait to take them out? My new plugs came in today and I'd like to put them in as soon as possible to get rid of that annoying CEL
ballface
Northern Illinois
98 New Beetle
I was going to say the exact same thing. If the OP bought a '98 NB and all it needs initially is a glow plug and a door latch, I'd say that's an easy start on a newly purchased northern NB!:)
Yeah it's been a catch for sure so far! Thing runs great but it's gonna need a little body work in the future as one of the rockers is pushed in and there's some big dents right above the drivers door
Rembrant
Canada's Ocean Playground
2013 Golf TDI DSG
I replaced a set of really rotten rocker panels on my 2000 Beetle last year...posted quite a few pictures in this thread if you're bored enough to read through it. Good luck with the car. I kinda miss my Beetle.
http://forums.tdiclub.com/showthread.php?t=378342
wonneber
Monroe, NY, USA
I think I sprayed mine 4 or 5 days.
I wanted to be sure it penetrated. :D
BobnOH
not-a-mechanic
central Ohio
I like wonneber's approach, it works.
When you can, tap it with a small hammer right after soaking.
2 days minimum
ballface
Northern Illinois
98 New Beetle
I was actually reading thru this thread the other day lol. Will definitely use it for help in the future when I do my own
wonneber
Monroe, NY, USA
Yeah I'm really scared of them breaking loose so I'll probably just do this spraying them up until the weekend just to be sure
I don't remember exactly but I think the max torque to take them out was around 25 -INCH- pounds. (not foot pounds)
Someone here will correct me if I'm off a bit.
Mine did not come close to that.
ballface
Northern Illinois
98 New Beetle
Thanks, I'll try and remember that if it's correct when I go to take them out some time in the next couple days
ballface
Northern Illinois
98 New Beetle
Got my glow plug problem all figured out now. Got the new ones in and still had a CEL. I started working my way out from there and come to find out I'm missing the glow plug relay under the dash! Does anyone know the part number for the relay on my 98 beetle? Is it the relay 180?
wonneber
Monroe, NY, USA
I would say look it up @ ID Parts
They are a trusted vendor.
I just got me timing belt kit from them.
BobnOH
not-a-mechanic
central Ohio
Yes, either you need both or either will work. You can call them or PM user IndigoBlueWagon or maybe someone will chime in. Seems strange yours was missing, perhaps they're under the hood? Also be sure to check the fuses, even the ones on top of the battery.
