nhkayaker17
I've got P0299 and P0101 codes giving me a CEL and Emissions Workshop alerts. I checked the VNT Actuator and it won't hold a vacuum so I figure I'll start with replacing that. What are my options to replace it? I've been looking online but have only found one place that carries the part. It's $369 but I'm not sure why it's so high.
Also, the OEM part number it lists, 03L198716A, also comes up as the actuator for the 2.0 TDI engines. Is this a mistake or do both actuators work for the BRM engine? There are plenty of part manufacturers for the CBAA/CBAB/CBDA/CBDB/CBBB/CBDC 2.0L part.
This is the only place I found that specifically lists the 1.9L BRM TDI VNT Actuator. Can you guys post others that might be cheaper or more reliable options?
http://www.idparts.com/vane-actuator-replacement-kit-a5-brm-p-3218.html
