robdog
So 18.75 oz. of freon is what the 06 takes? Mine is missing all labels under the hood and I plan to swap the valve this weekend.
Thanks, Rob
Thanks, Rob
Hi Dan.Both fans should always run together, at the same speed.
The fans are tasked to start AFTER the AC pressure has increased.
If the AC refrigerant control valve is not working (or if anything else prevents the AC compressor from producing more than 150 psig) then the fans will not come on.
You can test your fans with VCDS, engine module, output tests.
Hello All, following up and adding to information from post # 42, page 3.A heads up for anyone with the bolted in version - it doesn't appear to come apart nearly as simply as the snap ring version. After ordering the snap ring RCV from Polar I realized that I need the bolt one. I blew off the screen with clean compressed air, verified movement when applying 12v and measured 11.9 ohms across it before reinstalling it.
Very good to see another style!! Very curious which brand of compressor you have??Going through this now. On the bench, when I hit it with 12 volts, it clicks over every time. This is what mine looks like, no way I can see to get to the spring. Maybe mine is unserviceable? Either way, not sure where to go from here. Probably put the valve back in, recharge it and see what happens.
priceless ! Thanx.hello all, my a/c simply quit the other day, prompting an investigation, mostly to learn about it.
My first indication of a bad rcv valve was working fans, working a/c button lights, but simply warm air. The pressure also read 82psi (static) on the low side......way too much!!!! There was also a gurgling sound in the dash when turning off the a/c.
The low side service port is the line closest to the fender, with the larger diameter (3/4") aluminum line.
After a safe recovery of the refrigerant in the system, the valve can be removed:
The snap ring style is easily accessed with a 90 degree pair of snap ring pliers. The valve is tricky to get out. You will break off the plastic top hat and connector if you pry too hard!! Wiggle it, rotate it and as a last resort, 10 psi of clean, dry air introduced into the low pressure service port will help to push the valve out!!!!
Only a drip or 2 of smelly oil comes out. Note the bubbly air filled oil!!! The picture makes it look like metal fragments, but thats only bubbles. There are metal fragments, but very small.
There was a little bit of tiny metal debris on the valve and the filter. Most likely normal wear from the 150k (km's) on my compressor.
Here's where it would be easy to simply insert a new valve, but i wanted to find out what failed!!!!
The valve is a pulse width modulated (pwm) controlled solenoid valve, varying the displacement of the compressor, via the swashplate angle. It allows pressure to act, or relax the swashplate, depending on duty cycle, commanded by the ecm.
The solenoid part is simple, easily checking the resistance.
11.2 ohms.
Next was to see what stuck???
There is a small plunger and spring under an adjustable set screw:
Measured the depth of the set screw to allow accurate reassembly:
Now the little plunger was stuck, probably from tiny metal fragments. It easily came out with a gentle banging on a block of wood.
I cleaned everything and reassembled with a dab of loctite on the set screw to retain it.
The three orings got an inspection and lubed up, ready to test!!!
Testing:
For bench testing, i used a low amperage 12 volt dc power supply and "clicked" the solenoid. It moves very positive and travels the plunger about 1/16". Before cleaning, the plunger did not move at all.
Here's a vid:
http://i1059.photobucket.com/albums...62bf306-1867-000001b64860f12a_zpse9c0ceb6.mp4 .
I re-installed the valve into the compressor and charged with almost 19 oz to 36 psi, on the low side, while running.
Ice cold again!!
A new valve is not that expensive, i just wanted to determine what sticks in the valve and have a better understanding of the system.
Hope this helps avoid an expensive repair for someone else!!!
All the best,
andrew
This is interesting, so I rounded up a couple of different Snap Ring and bolted styles. The bolted in style does not have a set screw adjustment to capture the spring and plunger. However, you can carefully remove it with a dental pick, if you wish to clean it, or see why it failed.
Snap ring style left, bolt in style right.
Spring easily winds out, allowing plunger to be "unstuck" cleaned and re-installed.
Again, the valve is only $75 max, but it feels great to understand why it fails and certainly have a spare on the shelf!!!
All the best,
Andrew
