TNfirefighter
I have an 04 jetta that has just undergone several maintanence issues. The turbo was just replaced, intake taken off and cleaned, all of the solenoid valves removed and checked, all of the vaccum lines checked for leaks, and the inake manifold flapper motor replaced. vagcom shows no faults anywhere and the car still has zero power. any help on figuring this problem out would be appreciated.
Also could anyone tell me what the injector pressures should show using vagcom? should the readings all be the same or close?
car has 160,000 miles. oil used came from dealer and dont remember what it was. i did all the work.
