Dunno513 said:
Just wanted to throw my $.02 in here.
First, make sure you check your DSG build. Newer ones hold 1 litre more than the first NA 04-05 ones. Be prepared.
Second, stop and figure out the temperature range that they give you and apply a little logic to the WIDE range given. Anyone that says a specific tool is needed.. is a tool.
And finally, I honestly think that the design of the bottom fill method was two fold. First and foremost it allows a way to recollect the EXCESS oil so it is not wasted. $$$$ saver if you are a dealership.. the primary user of these. Second, it allows a greater fill speed, minimal, but over time a bennie to a dealership or mechanic.
This tranny is fillable thru the top. Plain and simple.
I wanted to post back here after the service. Couple of things to point out BEFORE you begin this adventure..
HAVE A 14mm or 9/16 Hex BEFORE YOU START !!!
or fabricate one by using a bolt with that size head and WELD a nut on the other end. I tried the double nut method, but I just couldn't budge it before the nuts spun Had to put it on hold while I picked one up from Sears. Not a very common size and most of your rinky dink auto parts stores don't carry that size.
And yes you can fill from the filter opening... But I caution you... S L O W...... Took me about an hour to pour 4.5 litres down the gizzard... pour a little, wait a minute, pour some more, wait..
There is one advantage to this procedure tho.... The garage is super clean and organized...
I'm not sure if I will make a fill tube or not for next time... It wasn't that bad, but make sure you have a transmission funnel, long slender one, before you start.
And if you own a beetle, you don't need to remove the battery and tray for this procedure even though the new Bently tells you to... and work around the line over the filter, there is plenty of wiggle room. There appeared to be what looked like a fill tube with a cover right next to the battery tray that would require it's removal but since I was already 1 quart into the snoozefest before I noticed, I didn't spend any time investigating it. Since I knew it would take some effort and time to remove the battery.. I plugged on... plus I was making good headway on my organizational skills.
Overall, anyone with a set of ramps, a 14mm or 9/16 hex, drain pan and a funnel can do this job with ease.
