stevieturbo
A friend took his good BLS apart to check the big ends, and replace and fit new rod bolts in a vain attempt at preventative work.Well i had a used engine (same engine code BXE) with 30000 miles fitted 2 years ago and now this engine has blown after 80000.(serviced at regular interval with specified oil) My mechanic has taken top half of engine off and the cam shaft shells are showing signs of wear and the cams themselves have a lip on them. He said it is signs of oil starvation.
i've had a mechanic friend of mine looking online at engine design and he said what is happening is the oil pump is run by a chain that drives a hex key off one of the pulleys and these get rounded off over time causing the oil pump to fail
Does anyone know what/if any other engine codes will drop straight in to my car that will be compatible with my ECU ?
Whilst there was some odd wear on the big end bearings, generally everything was in good condition with no obvious signs as to what may lead to a rod failure
more importantly, what actually failed on yours ? as the things you've listed are in no way related to the common rod out the side of the block failures
