Mahoutsukai
- Joined
- Jun 9, 2002
- Location
- Phoenix, AZ
I have a 2002 Jetta TDI with 59,600 miles.
I have an issue going on with my car that I need some help with. Before I spend time taking this to the dealer is there any quick solutions that I could try out first? I have a VAG-COM, timing belt tools, and other VW specific tools.
Symptoms:
-At idle the engine is fluctuating between 850-950RPM.
-My timing is within spec, but while looking at the timing graph for some reason it just goes blank for a second, and the engine makes a noticeable sound difference, almost like it is stalling. Then the timing graph comes back and repeats. (This seems to correlate with the fluctuations of the RPM at idle, although I can't see both graphs at the same time)
-The injection quantity (mg/stroke) was set around 6.5 but fluctuates from the high 5s to the low 7s.
-Power is down, car is running generally sluggish, and more than average smoke is apparent.
- I have recieved this fault code: "17656 - Injection Start Regulation: Control Deviation P1248 - 35-10 - - - Intermittent"
I have searched the forums and based on that here is what I have done:
-Replaced fuel filter (with CAT fuel filter)
-Checked the injector balance
-Cleaned all the electrical connections for the #3 injector, and the fuel pump.
-Checked MAP sensor, turbo is fine.
-Checked the MAF sensor, MAF is fine.
All these reported as working properly.
The only other possiblities I see are:
-Failed fuel pump
-Bad (G80?) needle sensor on injector #3
-Bad or needs screened cleaned on N108 sensor (Cold Start Injectior on pump)
Can anyone else suggest something I may be missing?
Symptoms:
-Failed fuel pump
