Old January 18th, 2016, 17:05   #1
Scottys248
Default Engine shudder at 1500 to 2800 revs B6 Passat
Hi guys,
I'm having trouble with my B6 2006 Passat after an engine repair which was necessitated by the oil pump drive shaft failing.
Had oil pump drive shaft, engine block, camshafts shells, timing belt, boost sensor replaced - (engine block from another engine).
I've just had injector no.4 and wiring loom replaced (due violent shudder and very poor power after engine rebuilt) and do not want to fork out for another one if this in not the most likely cause of the shudder - All 4 Injectors previously replaced by VW in 2011.
Between 1500 and 2800 revs there is an uncomfortable shudder of the engine which is worse under harder acceleration and in higher gears.
Below is the fuel injector assessment and the auto-electrician and mechanic reckon that injector no.3 is likely to be the cause.
Injector quantity deviation
1. -0.45mg/str
2. 0.0
3. 1.52
4. - 1.06
Is it likely that changing no. 3 will solve the issue? I've been told that although no. 4 was replaced, the deviation of this is so high due to possibly compensating for no.3?
Thanks in advance,
Scottys248 is offline   Reply With Quote
Old January 19th, 2016, 15:38   #2
Dimitri16V
Dimitri16V's Avatar
That high of deviation could be multiple things
Were the injectors correctly installed ? Adjusted right ?
Low compression in one cylinder will increase roughness and it will cause higher IQ deviation numbers . Were the rods from the replacement block checked for straightness?
Are the lifters and camshaft OK ? Fuel filter new ?
My bet is low compression
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old January 19th, 2016, 16:12   #3
Scottys248
Thanks for the reply Dimitri.
I think I remember the garage saying they checked compression etc and it is fine.
Fuel filter is new.
I'll check the other stuff tomorrow but the guys seem to know their stuff...but I wanted to be sure that another injector would be the perhaps the only item needing replaced before getting it.
2.0 TDI engine into a B6 passat? porkyvw TDI Conversions 7 April 8th, 2013 10:01
Misfire in 130 PD a4 at 1500-1800 revs technics100 TDI 101 1 June 14th, 2007 08:16
Passat B6 is coming with a TDI engine in 2007 rene2 General VW Discussion 2 September 20th, 2005 20:02
Shudder at 2400 to 2800 RPM PhilTX VW B5 Passat TDIs 38 May 16th, 2005 20:49
Diesel engine in the B6 Passat not coming to U.S. Route 66 VW B5 Passat TDIs 51 May 5th, 2005 08:05
Page generated in 0.15985 seconds with 11 queries
[Output: 58.81 Kb. compressed to 53.19 Kb. by saving 5.62 Kb. (9.56%)]
