rear axle removal
peegeez
Seattle
2004 V10; 2012 V6 TDI; 2019 Jetta
Has anyone removed the rear Axle on a V10?
My sway bar link failed and ripped up the CV Boot and I need to replace.
I looked on the DIY section and did not see anything.
If anyone has any information on this it would be much appreciated.
Blownvette
Derwood, Maryland
1990 Corvette with V10TDI ,2004 (2)V10TDI’s
It’s a easy job. Disconnect the parking brake cables and brake fluid lines and unbolt the sway bar mounting. Support the rear with a jack and unbolt the four subframe bolts and lower....
peegeez
Seattle
I would assume that you also have to remove the hub nut. I want to clean, re-lube & re-boot the CV joint on the outside drivers side.
So, I want remove the half shaft.
Blownvette
Derwood, Maryland
Yes. The hub nut and the inner flange bolts. I don’t honk a new axle is that expensive if you choose to go that route. I think it was about the cost of the boot kits the last I checked.
