miikepartyka said:
i have a 1999.5 Jetta
was wondering if i need to change anything if i get these two modules.
and what are the hp and torque gains for each
I have the same 99.5 jetta you have and originally had both a Van Aaken power box with the TPC boost controller. Both worked great together. I also upgraded my nozzles to PP520's. By setting the TPC at level 3 I could eliminate all the smoke and still keep my VNT-15 max pressure in the 17 - 18 psig range.
However I recently changed this to a KermaTDI chip for one important reason that I think is relevant to your Ontario location. And that is the inherent cold starting problem of the 99.5 tdi model year. The OEM ECU fuel map does not call for any fuel below 250 rpm. And when it gets really cold during the winter months this was causing me some really hard starting issues. Since changing to the KermaTDI chip these starting issues have totally disappeared. I also understand that the Rocketchip ECU upgrade also addresses this OEM problem.
Power delivery is about the same according to my butt dyno when comparing the two performance modifications.
