Old August 12th, 2018, 03:25   #1
itsmejerry
Default 2015 Passat Wrong fuel tank?
Okay.. Now I'm 100% convinced that in spite of what my owner's manual says, and in spite of what the literature for the 2015 Passat says about having an 18.5 Gallon fuel tank, Both of my Passats have 16.5 gallon tanks.
Although I've never gone past "5 miles until empty" on the readout before refueling, I've never been able to squeeze any more than 16.4 gallons into my 2015 Passat.
Sometime in the car's life I should have at least once or twice by now (80k on one Passat, and 6k on the other) been able to put 17-point something gallons in my car. I've never done that. Never
Anyone else experience this?
Is there a known campaign or fix by VW?
I'm about to take the car in to the dealer and get it looked at, but need to know if anyone else has had this issue.
itsmejerry is offline   Reply With Quote
Old August 12th, 2018, 04:53   #2
GoFaster
Moderator at Large
And what do you expect them to do about it?
The fuel tank that's in the car is the one that's meant to be there, because nothing else will fit that would have been available at the assembly plant to install (the Passat is manufactured in a completely different plant than any other VW, so it's not like someone could have made a mistake, even IF there is some other fuel tank that happens to fit in the car).
It may be wrong in the published specifications ... or there might be a fair bit left in it when the gauge says empty. (IF there is a problem with your car, I suspect it's the latter.)
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is offline   Reply With Quote
Old August 12th, 2018, 06:23   #3
turbobrick240
turbobrick240's Avatar
Yeah, there should be a gallon or more in reserve when the mfd first says 0 miles range remaining.
Old August 12th, 2018, 06:41   #4
scooperhsd
I would not recommend trying to find out by running it to empty - not a good way to treat fuel pumps.
2000 Red NB TDI, 350,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is offline   Reply With Quote
Old August 12th, 2018, 11:31   #5
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
If you really insist on knowing for sure, you can pull the pump under the rear seat, drain the tank, add 5 gallons, drive to the nearest fuel station and see how much you have to add to top off.
Fixmy59bug is offline   Reply With Quote
Old August 12th, 2018, 12:13   #6
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
Originally Posted by itsmejerry View Post
Although I've never gone past "5 miles until empty" on the readout before refueling, I've never been able to squeeze any more than 16.4 gallons into my 2015 Passat..
Sorry to say only an i***t would drive to 5 miles to empty.
The tank is 70 liters or 18.4 gal US.
Most I ever put in is 14 gal US or 52 liters. That's down to about 1/4 tank left.
"E" does not stand for ENOUGH !!!
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Old August 16th, 2018, 04:55   #7
Smashed Ixnay
You have the right tank. If I filled up around 30-40miles left it’ll be about 16.5 gallons. I have went 22 miles after my odometer said 0 miles left and it took 17.9 gallons. I never want to do it again.
Smashed Ixnay is offline   Reply With Quote
Old August 20th, 2018, 03:00   #8
itsmejerry
I'll do some tests and let everyone know.
The issue is with BOTH of my Passats.
Interestingly enough, I was able to Vag-Com my wife's car to where it shows "gallons needed to fill". Tonight the display reads "15 miles till empty, and 11 gallons needed to fill", so, I'm guessing this gives more credibility to the "2 gallons of reserve" position.
Old August 20th, 2018, 16:59   #9
Fixmy59bug
Fixmy59bug's Avatar
This last weekend I drove (accidentally) to where my MFI read 20 miles to empty.
It took me 16.874 gallons and I filled it to the neck.
On previous models, once the "Low Fuel" light came on, there were 2.1 gallons left in the tank. The RED part on the gauge was the reserve.
MAYBE on the newer cars the reserve is used once the gauge actually reads empty.
We wont actually know until someone pulls their pump the moment the light comes on.
2015 passat def tank DRFVWCLUB TDI 101 11 November 27th, 2017 23:31
Fuel tank capacity 2015 jetta? Darkhrse99 TDI 101 0 May 11th, 2015 23:10
fuel tank display is wrong ultranaut VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 March 7th, 2012 10:39
Fuel Tank/Fuel Gauge Issues with Passat michTDI VW MKIII-A3/B4 TDIs 29 May 10th, 2006 11:14
Wrong fuel in TDi tank TDI Jules VW MKIV-A4 TDIs (VE and PD) 3 February 1st, 2002 20:32
Page generated in 0.17212 seconds with 13 queries
[Output: 92.22 Kb. compressed to 78.89 Kb. by saving 13.33 Kb. (14.45%)]
