totitan
Rear sway bar only makes a huge difference. I used a H&R 22mm bar.
Front sway bar is a waste of money a piece of **** to install and hurts performance over a stock front bar and upgraded rear bar, just get the rear...Rear sway bar only makes a huge difference. I used a H&R 22mm bar.
Slowing tends to boost fuel numbers as well.Easy fix to handling problem: slow down.
And that investment automatically transfers to every car you own for the rest of your life, unlike most "mods."...
I'm a novice with 1000's of miles on the track. It's taught me that investing in the driver is the best investment.
I'd be interested to see if the MkV GTI rear bar is an upgrade, since it should fit and is probably available for cheap as a take off from the GTI fanboy racersI have the 24mm h&r rear with the 26mm front on my 14' jsw done at different times, and I can say with this configuration the front was as drastic as the rear bars improvement. I did the rear first and while it was infinitely better, it seamed as if it transferred some unwanted body roll to the front or made it become more apparent. Which was completely cured by the front bar. I would recommend this setup to anyone looking to ditch the roll. Everything else is stock, I'm tempted to do the walk kit or the super pro version. Anyone installed one of these on a jsw yet?
I put a MK5 rear bar on my JSW, it is an upgrade, only cost me $50, and made a noticeable improvement in handling. Then I added 17" tires, and it got even better.I'd be interested to see if the MkV GTI rear bar is an upgrade, since it should fit and is probably available for cheap as a take off from the GTI fanboy racers
If you are going to do lower control arms do yourself a huge favor and get the SuperPro units... they are awesome - they transform the feel of the car due to their bushings and by increasing caster too. They are a few pounds lighter than the OEM units as well.I'm running sticky tires (Bridgestone S-04) on 18x8's and a hotchkiss rear sway on the middle position with Bilsteins and Neuspeed JSW springs. It's awesome. I'm not feeling like I need a front sway. It blasts through the corners well. The front lag I feel seems to be bushings and not spring rate. I believe these cars handle very well with some alignment and these simple upgrades.
I've heard Passat Alu control arms fit. I've considered a mild camber increase.
