Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old April 2nd, 2020, 16:20   #1
Darkniss81
Default Hpfp
Is there any other way to tell if my HPFP is done other than metal in my filter
Sent from my SM-G930W8 using Tapatalk
Darkniss81 is offline   Reply With Quote
Old April 2nd, 2020, 18:50   #2
JSWTDI09
JSWTDI09's Avatar
Remove the fuel metering valve on top of the HPFP (2 torx screws, IIRC) and look into the hole and at the screen at the bottom of the valve. If there are lots of metal shavings in the screen, your HPFP has self destructed.
Have Fun!
Don
1966 MGB Roadster (just for fun)
JSWTDI09 is offline   Reply With Quote
Old April 2nd, 2020, 20:00   #3
DivineChaos
hopefully your still under warrenty
DivineChaos is offline   Reply With Quote
Old April 2nd, 2020, 20:01   #4
Darkniss81
No this is gonna be all on me
Old April 2nd, 2020, 20:19   #5
DivineChaos
ouch. hpfp and all injectors and the fuel lines. did you have a 1 micron filter in the injector return line? it might be worth cp3 conversion
Old April 2nd, 2020, 20:21   #6
Darkniss81
Cp3 conversion?
Old April 2nd, 2020, 20:39   #7
DivineChaos
yeah some have converted the cp4 for the cp3. not sure what all is required to do it. But if your hpfp is dead, you would have to replace it anyway. Not sure if you could have the injectors rebuilt also.
Old April 3rd, 2020, 06:27   #8
CheapBastard
CheapBastard's Avatar
TDI(s): 2014 JSW
Fuel Economy: 30
What year, I heard they are less prone to failure on 2014 models, any truth to this?
CheapBastard is offline   Reply With Quote
Old April 3rd, 2020, 06:33   #9
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
There seems to be less reports of failures for the 14 and 15 models. We know that VW/Bosch has changed the HPFP at least 4 times due to the letter at the end of the model number but no one really knows what changed and if the new pumps are that much better. The biggest thing is that if you had a faiure, make sure everything in the fuel system is clean as a whistle before you drop that new pump in. There have been horror stories of dealers ruining new pumps that way.
2010 silver/black JSW TDI with DSG, 2017 Ram 1500 EcoDiesel
kjclow is offline   Reply With Quote
Old April 3rd, 2020, 11:32   #10
Matt927
Matt927's Avatar
TDI(s): several
I thought the last major changes to the fuel pump were in 2012 or so, they changed some internal coatings. There were less built in 2014 before they switched to the EA288, so that might contribute to the lower numbers.
As for the CP4 in the EA288, I think the pressure is right about the same, different injectors though....solenoid in the 288.
Matt927 is offline   Reply With Quote
Old April 11th, 2020, 16:02   #11
3turboz
3turboz's Avatar
Fuel Economy: 37/42/48
Isn't the hpfp covered by the extended warranty?
Carl - GOLF TDI-Sold, T1N Sprinter, 280Z Turbo
3turboz is offline   Reply With Quote
Old April 11th, 2020, 16:29   #12
JSWTDI09
JSWTDI09's Avatar
...if you have a warranty. See posts 3 and 4 above.
Have Fun!
Don
Could it be HPFP? dan30thz28 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 22 December 15th, 2015 17:14
? about hpfp ts1989 TDI 101 3 August 14th, 2012 14:17
$ of JUST the HPFP? JungleDeath VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 October 10th, 2011 13:59
Besides the HPFP, what are the other..... STRANGETDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 14 September 21st, 2011 11:02
Page generated in 0.15116 seconds with 11 queries
[Output: 103.93 Kb. compressed to 86.94 Kb. by saving 16.98 Kb. (16.34%)]
