Old March 31st, 2020, 12:18   #1
DataDriven
TDI(s): 1Z
Default 1Z immobiliser intermittent issues
Dear all
I have a strange issue with the immobiliser of a 1Z engine out of a 1995 mkIII golf TDI installed in a T3 bus...
Every once in a while, but if so always from cold after not using the car for several weeks, the immobiliser will not work anymore, characterised by the typical 1s running and then dying again. This will be a pain in the butt up to about ten trials until it magically fixes itself.
I've checked the wiring several times and cannot find an obvious issue. - Testimony to that is that 99% of the time it will work absolutely fine, and it does of course always work when I'm around to try and diagnose it. - The joys of intermittent issues...
I was therefore wondering if these symptoms did ring a bell for people more knowledgeable than I am about these vehicles? Else, is there a way to check the immobiliser status during the issue with Vagcom / Hella Gutmann / ...?
Thanks in advance for your help!
DataDriven is offline   Reply With Quote
intermittent shifiting issues tat2 VW MKIV-A4 TDIs (VE and PD) 3 April 22nd, 2015 17:12
intermittent fuel cut on modded 1Z fletcher0780 TDI Power Enhancements 0 July 21st, 2014 07:33
HELP please, 1.9td 1z injector pump immobiliser problem, i think. large hideous green thing TDI 101 3 August 6th, 2012 15:23
1Z mk2 intermittent power loss, no codes set GTiTDi VW MKIII-A3/B4 TDIs 7 May 13th, 2011 10:29
tdi immobiliser problem (1z) lwbsjandy TDI 101 11 February 10th, 2010 00:26
© 1996 - 2020, All Rights Reserved
Page generated in 0.11610 seconds with 11 queries
[Output: 47.45 Kb. compressed to 44.77 Kb. by saving 2.68 Kb. (5.64%)]
