Parva
- Joined
- Mar 17, 2010
- Location
- Port Hueneme, CA
- TDI
- Now have a '13 Beetle Turbo, had a '10 Jetta Sportwagen TDI
So, I got the idea to replace (cover) the factory silver push button start/stop switch and it's black circular trim.
Apparently, all the ones I've found so far are all too small.
I see lots of examples listed on eBay & Amazon & AliExpress but they all appear to be the wrong size -- too small or don't list the size at all.
I measured & re-measured mine at the following sizes: The outer diameter of the black trim ring is 36mm wide & it's inner diameter is 28mm. The actual button is 25mm wide.
An example of what I'm looking for is this one at Amazon: https://www.amazon.com/gp/product/B0...13I4MKHG&psc=1 but its too small.
The ones online (again, the ones I've found), that list their dimensions have the following size: outer diameter of the trim ring is 29mm wide & it's inner diameter is 25mm. The button cover is 23mm wide.
Have you a place that sells the correct size?
