Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old February 18th, 2020, 12:13   #1
alxjhn
TDI(s): Q7
Default Front and Rear Differential fluid
What kind of front and rear differential oil does 2011 Audi Q7 TDI 3.0???? Transfer case????Also has 8 speed transmission.
alxjhn is offline   Reply With Quote
Old February 19th, 2020, 16:21   #2
bryanmabbott
Front and rear diff take 75w90; 0.8qt for the front, 1.1qt for the rear.
Transfer case take a specific fluid part number G 052 536 A2, 0.7qt.
Transmission fluid part number is G 055 540 A2, 6.3qt refill spec but IIRC when I did mine on my Touareg (same transmission) that spec is to account for overfill and you have to set the fluid level correctly by getting the trans up to temp via VCDS or IR temp gun and loosen the drain bolt with the engine on until all the excess fluid drains. I used Ravenol ATF-WS but you can easily use Toyota WS transmission fluid as it's easier to find and reasonably priced.
bryanmabbott is offline   Reply With Quote
Old February 19th, 2020, 20:21   #3
A1sailor
I used the Ravenol 75W- 140 GL5 for my 2015 Q5 transfer case, apparently VW ok'd and less cost that the OEM brand.
A1sailor is offline   Reply With Quote
Old February 29th, 2020, 12:28   #4
alxjhn
TDI(s): Q7
Default Atf in transcase
Is it atf or gear oil in the transfer case
Old March 1st, 2020, 16:56   #5
nayr
nayr's Avatar
TDI(s): 2014 Audi Q7
G052536A2 (Gear Oil) is OEM fluid for the transfer case
G052145S2 is OEM fluid for Diffs.
Ravenol TLS-LV is good alternative to OEM ATF, fraction of the cost.. it actually holds ~11qt but you can only get ~6qt out the drain, so do a couple changes 100 miles of eachother if you want to do a more complete change.. you end up using alot of ATF but your not paying OEM prices so its not that bad.
2014 Audi Q7 Prestige - Air Susp, ACC, Malone Stg2 w/RawTek DP/MidPipe, 245/65/17 BFG KO2, FrontRunner w/Full Size Spare, D710 HAM, Cayenne TCM, Webasto OEM Retrofit
1975 Westfallia 4MT - ALH Conversion in progress.
nayr is offline   Reply With Quote
Old March 2nd, 2020, 18:50   #6
alxjhn
TDI(s): Q7
Default Transfer case fluid
Can I use this fluid in the transfer case
Idemitsu 30040096-95300C020 ATF Type TLS-LV (WS)
Old March 3rd, 2020, 10:26   #7
nayr
nayr's Avatar
No, thats your transmission fluid.. transfer case is G052536A2.. there is no aftermarket equivalent afik.. you only need like one bottle, suck it up.. minus engine, you need 3 different types of oil to do a full drivetrain lube job.. Diff, Transfer Case, Transmission are all different.
Old March 3rd, 2020, 12:30   #8
alxjhn
TDI(s): Q7
So it only takes 1 bottle for the transfer case????G052536A2 (Gear Oil) is OEM fluid for the transfer case... i already did the transmission filter and fluid change. Used febi atf and filter kit from ecstuning. I used redline 75w 90 in the front and rear differential.
Old March 3rd, 2020, 17:09   #9
nayr
nayr's Avatar
~0.7L capacity of gear oil for transfer case, G052536A2 is 1L..
0.7 < 1
so it only takes 1 bottle of G052536A2 for the transfer case.. the very first reply to you contained all this information.
differential fluid change gotsoot VW B5 Passat TDIs 11 August 9th, 2015 07:03
Front and Rear Washer Fluid Golf duwem VW MKIV-A4 TDIs (VE and PD) 5 September 18th, 2012 17:37
O1m Differential Fluid? evileltdude TDI 101 2 March 26th, 2012 16:20
Rear washer fluid spraying when front washer fluid and wiper activated rojhero VW MKIV-A4 TDIs (VE and PD) 4 January 12th, 2011 05:26
Differential fluid change? Bugger TDI 101 9 September 8th, 2010 09:01
Page generated in 0.14192 seconds with 11 queries
[Output: 90.08 Kb. compressed to 76.81 Kb. by saving 13.27 Kb. (14.73%)]
