Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old September 8th, 2015, 14:41   #1
Nathan123086
Default Won't start/turn over. No tail lights, AC, dash lights and windows do not work.
Its a 2012 tdi w/ 80k was driving it this morning and most dash lights went out, windows quit working, tail lights/brake lights and blinkers don't work. Drove it home 20 more miles and turned it off in my driveway. Car won't turn over. The battery is still good, most interior lights are still bright as they should be. Radio still works. The glow plug light is flashing and another light with I think the number one was in center. Any suggestions?
Nathan123086 is offline   Reply With Quote
Old September 8th, 2015, 18:01   #2
dirtysouthjacket
dirtysouthjacket's Avatar
Find someone with VCDS or a tdiguru. There is also a fuse diagram list in the How To section. Unfortunately electrical issues on the new platforms can be very difficult to troubleshoot now because of the Can-bus.
2012 Jetta TDI Premium; Dual Horn, Hybrid Grill, bunch of sound deadening to install
2004 Jetta TDI GLS - SOLD
1991 Mastercraft ProStar 190
2011 BMW F800GS, 2003 Kawasaki Super Sherpa, 1997 Kawasaki KDX200
dirtysouthjacket is offline   Reply With Quote
Old September 8th, 2015, 18:07   #3
Nathan123086
Getting it towed to dealership tomorrow. Luckily my roadside through geico will tow it 98 miles to nearest dealer. After talking to buddy that used to be vw mechanic he said it probably is something in the ignition.... Second time I've had to have it towed. First time was for a similar issue duty to improper installation of ignition...
Old September 9th, 2015, 14:08   #4
Nathan123086
Bill is $599 so far and they aren't even sure if that'll fix it. I guess they've never seen this issue. Least I had roadside. Tow truck driver said that it was an $800 tow.
Dash lights won't turn off. MaxThrust TDI 101 34 December 29th, 2016 17:54
No start, No dash lights, no power windows sosnpk VW MKIII-A3/B4 TDIs 2 September 27th, 2012 07:58
'02 Jetta won't start, dome lights and gauges work, Ground Problem? hartzpad TDI 101 4 August 21st, 2010 20:26
Won't start...no power to locks, trunk, windows, interior lights and sunroof. psychadila TDI 101 26 April 28th, 2008 13:12
Page generated in 0.16284 seconds with 11 queries
[Output: 62.27 Kb. compressed to 55.79 Kb. by saving 6.48 Kb. (10.41%)]
