Old March 1st, 2020, 19:21   #121
3L3M3NT
3L3M3NT's Avatar
Here's the new turbo setup and manifold.
I was able to find a replacement BHW engine just outside of the Twin Cities and was able to have a friend pick it up and drop it off at my buddies place near Oshkosh. This time I'll be sending the pistons, turbine housing, and manifold out to get ceramic coated to hopefully help manage the heat a bit better.
I'll post another update when the parts are back from ceramic coating and are getting ready for install.
I posted this in the W/M thread, but I figure I might as well post this in my thread and see if people wanna weigh in on installing W/M on my car.
I'm considering adding Water/Meth to my car to keep the EGTs in check. I primarily use the car for HPDE(track days) and would like to keep the EGTs to around 1500F, since they currently push into the 1600+ range on the straightaways. I'm open to other suggestions as well.
Here are some of the options I've found. Ranked in the order of 1st choice to last choice.
https://cppdiesel.com/snow-45006-pow...nol-injection/
http://www.alcohol-injection.com/en/...tank_black_lid
https://www.aquamist-direct.com/806-...etCurrencyId=2
Thanks for taking the time help me figure out what my best option is.
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
October 19th,2019 Cruise/GTG in Sturgeon Bay, WI
3L3M3NT is offline   Reply With Quote
Old March 1st, 2020, 20:46   #122
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
If you want better control over EGT's, put in bigger nozzles/injectors and dial the fuel delivery back in the tune to an equivalent amount. Basically, anything more than a very light haze of smoke out the back is going to cause broken parts with what you're doing - Keep Air Fuel ratio's in the 18-20:1 range max.
I'd consider this before a water (only water, no meth) injection system and all the extra complexity it adds (and risk if it doesn't work).
Some close up photo's of the piston bowl lips would be interesting to see - Cleaned up with some solvent and paper towel (no media blasting or physical removal). If you can't find any reason for foreign object damage in cylinder 4, maybe a piece of piston broke off?
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is offline   Reply With Quote
Old March 1st, 2020, 21:12   #123
3L3M3NT
3L3M3NT's Avatar
The thing is, is that I've got some pretty big injectors in the car right now. I even went from the +80% Firad nozzles to +120% Firad nozzles on a set of PD100 injectors, which is supposed to be good for 330bhp. My car dynoed at 286AWHP and 404 lb-ft of torque, so I should have plenty as far as fueling goes.
I just think the tune needs to be dialed back for what I'm doing and be less concerned about dyno numbers. Like you mentioned, the car needs to be putting out a low haze and not a plume of smoke everytime the car is coming out of a corner or a gear shift is made.
That's probably a good call on not adding a W/M kit(water mostly kit ) Just one more thing to go wrong and add to the complexity of the car.
I'll see if the guy working on my car can get some better/close up pictures of piston 4 to see if there's a chunk of piston missing that went out of the exhaust and into the turbine wheel. It's either that or the possibility that the tip of the injector broke off and caused that damage... I'll see if I can get some better pictures of both piston #4 and the injector from cylinder 4 and post them up.
Firefox fix
RTDI Build Thread
Old March 6th, 2020, 18:54   #124
Fix_Until_Broke
Random thought while driving down the road today - you'll likely need at least 1 new nozzle. May as well go big
Old March 21st, 2020, 21:25   #125
3L3M3NT
3L3M3NT's Avatar
To be honest I don't think that I need to go to a larger size nozzle. The +120% nozzles flow enough for 330bhp and for what I'm looking to do with the car that's more than enough to fuel my car. With the piston failing in cylinder 4 and the turbo getting taken out in the process has me rethinking how much I wanna push this engine setup.
Adam at Pioneering Performance suggested I dial back the fueling after he saw how much soot was built up on the hot side of the turbo and I can understand why after I told him how many hours were on that turbo.
I'd rather start on the lower end of the power spectrum and bring it up little by little until it's making good power, but out of the threshold where it could blow up.
Firefox fix
RTDI Build Thread
Old March 26th, 2020, 19:40   #126
3L3M3NT
3L3M3NT's Avatar
With the engine needing to be rebuilt, I decided it would be a good idea to ceramic coat the pistons this time around. My mechanic sent the pistons to Swain Tech Coatings to have them coat the top of the pistons with their Gold Coat and had their PC-9 coating on the skirt.
The pistons look pretty darn good from the pictures my mechanic sent me yesterday when they arrived at his place.
The coating looks a little bit different in the daylight.
Now we're just waiting on them to coat the turbine housing and exhaust manifold and then ship them out when they're done. Unfortunately it might take a bit longer than it normally would with the coronavirus forcing them to adjust their production schedule. Fingers crossed that they can get them coated in the next couple of weeks.
Firefox fix
RTDI Build Thread
Old March 27th, 2020, 06:16   #127
Kevinski4
Kevinski4's Avatar
Smoke is power that you can see but not use.
Kevinski4 is offline   Reply With Quote
Old March 31st, 2020, 21:42   #128
3L3M3NT
3L3M3NT's Avatar
If cylinder 4 hadn't failed at the track my plan was to dial back the fueling to clean up the amount of smoke coming out of the exhaust and try and get it closer to a light haze. After this rebuild we'll definitely be dialing the fueling back to increase the longevity of all of the engine parts and turbo.
Then on a side note...my mechanic friend got the turbine housing back from being ceramic coated. It turned out fantastic imo.
Firefox fix
RTDI Build Thread
RTDI Part 2 3L3M3NT Golf TDI Picture Gallery 142 April 20th, 2020 22:38
Full on RTDI build up. mtbr297 TDI Conversions 74 June 9th, 2015 05:43
Broke a part inside injector fuel pump. Can't find where to buy new part. Any ideas? 03TDIJettaWagon VW MKIV-A4 TDIs (VE and PD) 7 October 26th, 2014 11:06
2006 UK TDI Road Trip Part I: Wales Part 2 PlaneCrazy Road Trips 4 August 29th, 2006 18:19
2006 UK TDI Road Trip-Part I: Wales part 1 PlaneCrazy Road Trips 0 August 15th, 2006 18:39
Page generated in 0.16040 seconds with 11 queries
[Output: 104.18 Kb. compressed to 91.73 Kb. by saving 12.45 Kb. (11.95%)]
