Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
View Poll Results: If you have experienced intercooler icing, select from the following options...
I have experienced a hard start / no start / power loss with my original intercooler 118 86.13%
I have experienced a hard start / no start / power loss with the UPDATED intercooler 19 13.87%
Voters: 137. You may not vote on this poll
Old January 29th, 2019, 08:08   #271
2dye4
TDI(s): Jetta
Just experienced this for this first time, did the usual, took pipes apart, goopy slime came out with minimum water. I took apart the upper pipe that connects to the throttle body and flushed out the entire pipe with brake cleaner, blew out all the remaining debris/cleaner and it runs perfect again.
Is the TSB still open? 2013 with 82k miles?
Thanks!
2dye4 is offline   Reply With Quote
Old February 1st, 2019, 02:47   #272
Matt927
Matt927's Avatar
TDI(s): several
As far as I am aware, Volkswagen is still installing kits.
Matt927 is offline   Reply With Quote
Old February 2nd, 2020, 10:36   #273
06bluebeetletdi
I have the kit on mine. First time 1/17 - 53,000 miles, towed it and had cold weather kit installed under certified preowned warranty, 2nd time - 1/20 -89,000 miles - drained 2 1/2 cups of water out of the intercooler- towed it under dieselgate roadside assistance- i killed the battery and thatís why it wouldnít start after emptying the intercooler pipe. So, donít view the kit as a fix, i am going to drain the pipe at every oil change and be very aware of humid and cold weather (just have to drive my gen 2 Passat instead of the bug).
06bluebeetletdi is offline   Reply With Quote
Old March 14th, 2020, 16:18   #274
06bluebeetletdi
Update: its been about 6 weeks and 1400 miles, the bug has a winter front for days below 60*. I checked the intercooler hose today, ONLY 3 drips came out! Yay! Will update in 5,000 miles.
Hard Start / No Start - Is your intercooler frozen? Check Here! GraniteRooster VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5446 April 18th, 2020 12:45
Golf tdi 99 hard start from cold and yesterday won't start at all deep_sing VW MKIV-A4 TDIs (VE and PD) 17 December 13th, 2013 06:48
Hard start problem, still after going every hard start thread snowboardphil VW MKIV-A4 TDIs (VE and PD) 9 July 6th, 2013 17:31
98 Jetta tdi Hard to start hot, now no start DRVRFWND VW MKIII-A3/B4 TDIs 6 February 7th, 2011 22:01
Discussion: 01 Jetta no start paramedick VW MKIV-A4 TDIs (VE and PD) 11 June 30th, 2008 14:24
© 1996 - 2020, All Rights Reserved
Page generated in 0.12551 seconds with 12 queries
[Output: 66.81 Kb. compressed to 60.29 Kb. by saving 6.51 Kb. (9.75%)]
