bbob203
I wanted to have no electronics. Though a standalone electronic system would be better than an ecu I'd still rather keep it all mechanical.
Probably pointless to post any logs since you are running such an unusual setup.I made a boost log I will post later. After speaking with my tuner earlier today he brought to my attention that I am not running an intercooler which is true and so the air heating up is likely causing the pressure to slowly increase. Makes sense to me. This is why I wanted testers because my engine is not exactly stock as I have been running water/meth and without an intercooler. Also I have no maf sensor. Other than that it is fairly stock.
It really is to bad I live 10 miles through the city from the nearest highway to do testing. I have not experienced any spiking at all even stabbing the throttle. Boost response will be immediate but it is also directly tied to cruising boost. Right now boost response is very quick but I also have it set lower than normal just to experiment. What I am doing is adjusting the set screw a quarter turn at a time until I achieve a sweet spot. Alternatively the idea just entered into my mind tonight about using the n75 valve and the computer to regulate pressure as the actuator is a dual port unit. I wonder if the n75 from the gasser motors can operate at higher boost levels. If they will swap over then instead of controlling vacuum it will bleed boost whilst still retaining another spring. Just need to install a really soft spring in the actuator. Then it would be a smart system again lol.My goals are a reliable 25 psi of boost without spiking, quick throttle response, lower egts and better top end power. My k14 is great until about 3000 rpms and it runs out of breath but off the line its a great turbo it gets up to my max boost of 19 psi quickly. I like cruising boost to be about 7psi or so at 70mph.
At least put an I/C back on or have you turned off the IAT in software?
Plenty of options at a reasonable cost...
This whole thing really smacks of a solution looking for a problem, IMO.
Call me synical, I see a different motive from oems. I see profit as the motivating factor. Lessons learned...from an emissions standpoint to get epa certification in order to sell vehicles...yes. Engines are so complex today it boggles the mind. The plugged intakes from computer controlled egr is a great example of "lessons learned". The "simple" solution...block off the egr. Oems never fixed the oil soot mix plugging our intake systems and intercoolers. Numerous methods are orchestrated by guys like myself to remedy problems with various results. Some work better than others. Guys like me buy or build solutions to fix these "lessons learned". Since my target group is anyone not under a factory or extended warranty I am no different than anyone who came before me to offer alternatives. If you have factory warranty coverage I would not even begin to mess with the vehicle. With all of my "unusual" mods that are "so different" from the norm, I still manage to pass emissions every year and maintain decent fuel economy. I may be down on power with the apparent solution being that of an intercooler. Simplicity has its place.For the record, I do see the value of something like this for conversions. Even then, most will want to transplant the ECU to integrate w/all the sensors and closed-loop systems other than boost. The boost system, as it exists, tries to take into account numerous factors like air temp, air mass, etc. I don't see those as frivolous but rather a compilation of 'lessons learned' in an effort to better control the amount of boost. It is not a perfect system by far but most with issues are having them due to a mechanical issue like vacuum loss, leaky actuator, sticky vanes, etc. Innovation is the product of folks like yourself trying new things so, by all means, carry on. Simple is better so on that we agree.
Throwing the baby out with the bathwater would also apply here.
The VNT system was designed to give basically all the items mentioned in this thread as a "goal", namely making a reliable, responsive turbocharger that can handle more power than a small turbocharger and spools faster than a large one would and therefore allow good power and good efficiency.
All the "issues" with it are things that are either emissions related (soot buildup), easily fixed (stuck actuator) or limitations in the relatively primitive control system (allowing turbocharger spiking). The solution to this is to fix the issues, not make the car run worse by disabling the system.
If you want to manually control the boost or use a non-electronic control you would be better off swapping to a good waste-gated turbocharger that was designed better for more static operation.
Read his post again as he's not discussing those merits.Don't do it here...
I read his post, he compared the two schemes and made a recommendation based upon the merits of both. It's very chivalrous of you to defend someone him, you two must be very close. I have concluded my op lists all the "direction" intended, I cannot apologize if you can't follow along. I disagree with your theory that all intellectual property should be freely given away. I believe Ayn Rand wrote a book about that, Google it. Minus disclosing actual intellectual property via pictures which, in all honesty and embarrassingly enough I can't seem to post, it is a very basic and simple principle to grasp moving a rod 12mm or so back and forth. If you cannot grasp that principle then I don't think there is anything you can add of value for or against what I have done here. As for "expectations", since you failed to state yours, I have to reasonably infer you mean mine, of which I have more than exceeded. So ill take it as a simple bombing of my thread which is greatly unappreciated. Please don't do it again.Read his post again as he's not discussing those merits.
As you've yet to provide us with anything but talk at this point in time, this thread has little direction. Post your solution as if it were not a trade secret and then we can actually add value to what you're doing here. Until then, you kinda aren't living up to expectations
To have the same or better response from turbo
To eliminate or minimize or eliminate "spiking"
To to maintain or increase fuel economy
To maintain or increase reliability
To eliminate vanes "sticking"
To be user tunable (if needed) without computers
To have maximum spool with user definable maximum pressure
Vanes default position are closed instead of open, so in case of failure
turbo will still produce pressure, instead of no pressure.
Are you able to taper off boost at the higher RPMs? (To allow higher boost midrange and taper off to avoid overspeeding the compressor wheel?) If not, it isn't operating like factory boost control and you are not able to get the same peak torque figures out of it.I can guarantee It will operate just like factory.
