Old July 17th, 2011, 19:18   #1
GardRail
Default Timing belt fun
Managed to get to the point in the timingbelt how-to where the valve cover is to be removed and discovered that the previous owner may have cranked down two of the bolts way too **** tight. What would be the best tool to try and remove stripped out alan bolts? Would an Irwin bolt-out be more reliable than beating the thing with a cold chisel?
I've removed the intake again to give myself a bit more room...
2k2 Golf TDI alh/01m -- 162k miles -- TDIHeater
GardRail is offline   Reply With Quote
Old July 17th, 2011, 21:00   #2
MrBigTruck
I bought these sockets
http://www.craftsman.com/shc/s/p_101...1&blockType=L1
I found the one socket in the set that was a little too small to go over the outside of the head of the valve cover bolts, put an extension on it, and beat it onto the outside of the bolt. The bolt head was soft enough that it actually formed little grooves in it and the socket could grab the head. It may work with a standard 12 pt. socket as well. You'll have to order some new bolts. I always order a bunch just in case I screw one up or if nothing else you'll have some for next time. Every time I take off that valve cover, I put in new bolts. They're 85. Order 10 or so.
http://www.idparts.com/catalog/produ...roducts_id=936
MrBigTruck is offline   Reply With Quote
Old July 18th, 2011, 02:24   #3
flatlanded
TDI(s): 2002 Jetta
Fuel Economy: 55ish US MPG
Boltouts work great. You might have to remove the intake to gain access to the back ones if they are (and they usually are) the ones in question.
'02 Jetta TDI - 400,000 kms: Frostheater, boost/egt/oil-temp gauges, evolution skidplate, 5 brake light mod, 17/22, PP520, Malone Stage 5, 2.5" side-pipe, SBC Stage 2 Endurance
**Have VCDS**
flatlanded is offline   Reply With Quote
Old July 18th, 2011, 02:45   #4
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Yup, Craftsman or Irwin bolt-outs are where it's at. Added a set to my TB tools based on the last one I had to do. Pick the one that fits snugly, tap it on with a ball-peen hammer and insert a 3/8" socket & extension to easily remove the bolt. And put a tiny, tiny bit of anti-seize on the new bolts when you put them in.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old July 18th, 2011, 03:47   #5
GardRail
That was exactly what i was going to ask - which brands / type. I'm going to see if I cant run out to Sears to get a set of bolt-outs. I've seen anti-seize used on here from time to time - what brand does everyone typically use?
Old July 18th, 2011, 04:34   #6
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
I've used Permatex regular, nuclear-grade nickel-based & marine-grade copper anti-seize. All of them have worked well, and should, as this isn't a terribly demanding application. Just be sure you only put the tiniest, thinnest dab on the bolts, roll in into the threads with your finger and be certain your hex socket is firmly seated in the head before tightening.
Old July 18th, 2011, 06:31   #7
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Torque spec is 7 ft.lbs. (~84in.lbs)
runonbeer is offline   Reply With Quote
Old July 18th, 2011, 06:42   #8
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Before you even try to remove them you give them a love tap with a hammer. Breaks them free and they come right out.
Jason, Service work available. www.jasonTDR.com
Give a hand,www.akitas.org
jasonTDI is offline   Reply With Quote
Old July 18th, 2011, 09:01   #9
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☠☭
Good advice on the love tap - also works to make sure your hex drive socket is seated well in the head. Sometimes it also helps to tighten the bolt slightly first before removing it.
Old July 18th, 2011, 09:30   #10
GardRail
awesome advice!
I def plan on torqing the bolts down to 7ftlbs when I complete the job - I'm wondering if someone followed the gudntight method with a longer ratchet.
Old July 18th, 2011, 09:45   #11
Powder Hound
Powder Hound's Avatar
The bolt out set is a really good idea. The other place you will need it is when you go to remove the harmonic balancer. I've only done 8 TB replacements, but I have not done one yet that didn't need the bolt outs on 1 or 2 of the 4 in the balancer.
Old July 18th, 2011, 09:53   #12
GardRail
I look forward to having all sorts of foul language emenating from the garage. I probably should wait until the kids go to sleep before I start in on the balancer.
Old July 18th, 2011, 11:46   #13
GardRail
I just got back from Sears and bought the cheapest set of bolt-outs I could find. The valve cover bolt took a #4, and after tapping it on with a hammer, the bolts came out like someone lit a fire under their asses!
Bolt-outs are right up there with helicoils in my book. whoever came up with the design for both of them should be nominated for some sorta award!
Old July 18th, 2011, 18:18   #14
jasonTDI
jasonTDI's Avatar
Huh.....The HB bolts. Only need the bolt out on one out of 20 cars...MAC allens help. Quality ones. Also use a LONG thin rachet that has some flex. It snaps them loose.
Old July 19th, 2011, 05:02   #15
runonbeer
I use an impact. Rarely do I round them out.
A5 JETTA TDI TIMING BELT KIT BRM $175 and Timing Belt+ alternater pulleyTools $65 kstef Private TDI Items for Sale/Wanted 1 August 29th, 2010 05:05
Golf TDI TIMING BELT CHANGE / TIMING BELT PINS POSITION grahammarkwoods Golf TDI Picture Gallery 3 October 9th, 2007 08:56
Broken timing belt, come join the fun! Now w/ PICS tarbellb TDI Power Enhancements 13 June 23rd, 2005 12:57
$746.00 for a timing belt change??? Stealer is a couple of fries short of a fun meal! dbbrowne VW MKIV-A4 TDIs (VE and PD) 11 May 4th, 2002 00:17
Timing Belt & Water Pump or just Timing Belt Flashman2 VW MKIV-A4 TDIs (VE and PD) 13 June 28th, 2001 09:31
Page generated in 0.16270 seconds with 11 queries
[Output: 130.75 Kb. compressed to 109.00 Kb. by saving 21.75 Kb. (16.64%)]
