Old July 8th, 2008, 07:47   #1
elan
Default coolant loss
Read up a lot on here about coolant loss, still cant find the answer so,
I have a Passat 130 BHP PD 2001 (UK), had the rad and water pump changed, still useing coolant, if I drive harder the more it seems to use, no black deposits in expansion tank, no emulsion in oil, drives ok, no great clouds white smoke, no misting of screen when heater on, having a pressure check next week, any ideas please?
elan is offline   Reply With Quote
Old July 8th, 2008, 07:54   #2
bayshorecs
bayshorecs's Avatar
TDI(s): 06 Golf
Fuel Economy: 40
Nothing on the ground overnight?
It is going somewhere, either on the ground or out the tailpipe.
152k miles - 06 Golf Auto with skid plate, ventectomy and 5-light brake mod
bayshorecs is offline   Reply With Quote
Old July 8th, 2008, 07:59   #3
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Have a sample of the motor oil analyzed for the presence of coolant. Look for traces of dried coolant that may be being "cooked' on a hot exhaust manifold or downpipe from a small hose leak.
Good luck,
Tony
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old July 8th, 2008, 08:33   #4
Radman
Possibly leaking into the EGR cooler and burning off through the exhaust.
2014 Audi A6 TDI, Unitronic Tuned
2014 Touareg TDI, Unitronic Tuned
Radman is offline   Reply With Quote
Old July 8th, 2008, 09:02   #5
bayshorecs
bayshorecs's Avatar
TDI(s): 06 Golf
Fuel Economy: 40
All the more reason for an EGR delete via racepipe!
Old July 8th, 2008, 10:09   #6
elan
Thanks for the quick replys, no water on the ground.
Read about the EGR cooler, where is it exactly? had a look through Haynes book and it dont even mention it?
Old July 8th, 2008, 10:23   #7
bayshorecs
bayshorecs's Avatar
TDI(s): 06 Golf
Fuel Economy: 40
Follow the coolant lines. On the A3 and A4, it is mounted to the intake manifold on the back side of the motor, next to the firewall.
Old July 8th, 2008, 11:38   #8
Radman
On the B5.5 it is along the passenger side of the engine. If leaking internally it may not be visible.
My EGR is disabled via the chip. I plan to completely remove it soon and bypass the coolant hoses. Anyone have a picture of the backside of the engine showing where the hoses go?
Old July 8th, 2008, 17:59   #9
MOGolf
MOGolf's Avatar
Not all of the AVF and AWX engines have EGR coolers.
Look at the intake. Below the round disk part of the EGR valve is a metal tube. That tube either connects to the EGR cooler (a long silver tube shape with coolant hoses attached) or it attaches directly to the exhaust manifold.
Did the seal for the replacement water pump actually seal? I've seen seals damaged during the installation resulting in coolant leaks.
Its going to be a matter of looking at every single hose connection for evidence of coolant deposits, the radiator, and other coolant seal locations.
MOGolf is offline   Reply With Quote
Old July 9th, 2008, 00:05   #10
elan
probably thats why I cant find it, below the EGR valve there's a metal pipe that attaches to the exhaust manifold.
thanks for the help
Old July 9th, 2008, 00:29   #11
muffin
Fuel Economy: 45
Elan,
You will not have it, in the uk we dont, just the vacum pipe at the top, and the silver pipe to the exhaust manifold.
You say you have had the water pump replaced and the rad, when they did the water pump did you also do the thermostat, it has been know for these to leak, as its a rubber seal and can be pinched...and around here depending on loss might be enough to evapourate...
How much are you using ???
Muffin
Audi A6 Avant 1.9tdi SE/Sport (130bhp) 69K - 160K so far......
Audi A4 Avant 1.9tdi SE (115bhp) 6K - 69K
Audi A4 Avant 1.9tdi SE (110bhp) 23K - 60K
muffin is offline   Reply With Quote
Old July 9th, 2008, 10:11   #12
elan
just done 120 miles and put in between 2-3 litres
Page generated in 0.15664 seconds with 10 queries
[Output: 100.71 Kb. compressed to 83.74 Kb. by saving 16.97 Kb. (16.85%)]
