Mongler98
- Joined
- Mar 23, 2011
- Location
- COLORADO (SE of Denver)
- TDI
- 98 Jetta TDI AHU 1.9L (944 TDI swap in progress) I moved so now i got nothing but an AHU in a garage on a pallet.
In my conversation swap on the 944 I plan on mounting the ahu in. 90* up and down. I'm running a dry sump to A: clear the steering rack and sub frame on the 944, and B: to lower the engine so it will clear the hood. I'm going to run an electrical water, ps, and possibly ac, but the engine needs more or less to sit 90* upright to clear enough room for the compound turbo and for the block to clear the steering shaft to the 944s sub frame.
My question is, what drawbacks to this orientation are there? Only thing I can think of is the oil pick up (solved for other reasons) and the drain of the oil on the head. Will it pool up excess oil on the head? What else could be an issue and how can I solve it?
