Old January 16th, 2018, 18:26   #1
Bill Jackson
TDI(s): Jetta
Default ALH Throttle Pedal Wiring Info
Hi Iím needing to know which wire is what that comes out of the electronic pedal such as what is ground, 5v supply and signal.
Bill Jackson is offline   Reply With Quote
Old January 16th, 2018, 19:55   #2
Exenos
TDI(s): 02 Golf
If you can find the ecu pinout you can probably get most of that from referencing the wire colours. There was also a post a while ago about some guy putting a alh style pedal connector on his ahu harness. That might have what your looking for.
Exenos is offline   Reply With Quote
Old January 16th, 2018, 20:17   #3
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
These might help..1 on the left,2 on right
1.9ZOOK is offline   Reply With Quote
Old January 17th, 2018, 09:21   #4
Bill Jackson
TDI(s): Jetta
I donít think thatís exactly what Iím looking for. Iím doing a automatic swap and trying get my shift signals off the tps in the gas pedal. From what I understand half the pedal tells the injector pump what to do and the other half is your shift signals for automatic transmission. I need to know which wire supplies the tps with 5v which wire is ground and which wire is for signal.
Old January 17th, 2018, 09:25   #5
Vince Waldon
Vince Waldon's Avatar
Yup, that's the above posted schematic, top one, lower left hand side.
Labeled "Throttle Position Sensor"... you can see the variable resistors that form the actual position sensor and the kickdown switches.
There's no "5V" type signals per se... it's a purely analogue sensor.
EDIT: meaning, no 5V digital output signals...I shoulda been clearer. Hasenwerk has posted the actual pin-outs below.
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old January 17th, 2018, 09:53   #6
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
I tried to get all destinations of the wires,would have been too small with 1
photo.
Old January 17th, 2018, 10:12   #7
Hasenwerk
Hasenwerk's Avatar
MK4/5 Accelerator Pedal, 1x6 terminal
1 - F8 Engine Control Unit (Kickdown Switch: 0-90% = 9+V >90% = 0V)
2 - G79 Engine Control Unit (5.0V)
3 - G79 Engine Control Unit (GND)
4 - G79 Engine Control Unit (0% = 0.35V 25% = 1.1V 50% = 1.7V 75% = 2.3V 100% = 2.85V max = 4.5V)
5 - F60 Engine Control Unit (Idle switch - Signal: 0% = 0V, >1% = 2.785V)
6 - F60 Engine Control Unit (Idle switch - Ground)
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old January 17th, 2018, 13:49   #8
Bill Jackson
TDI(s): Jetta
Ok thanks a lot everybody I think that answers my questions.
Old April 2nd, 2020, 09:11   #9
D-cappz
Hi, not wanting to jack the thread, but I wanted to ask if pin out 4 would read 0-100% Thottle gradually or does it only read it at 25% increments? Iv got a stand alone controller that I need to have a 5v Thottle position signal from and I need it to read 0-100% all the way through. Example: 5%, 18%, 62% and so on.
Upgrades:
MK4 4motion swapped 02M ALH 1.92L, Kerma Tune, 1726, DLC764, Port & Polish, OS Valves, Dual Valve Springs, Colt Cam Stg2, Molnar H-beams, ARL 80mm, Kerma ďOMIĒ, PD150 IM, Kerma FMIC, Kerma CCV, SBC Stg2 Endurance, Wavetrac LSD's, Sigma, custom cluster ColourMFA
http://www.instagram.com/MK4mo_TDI
D-cappz is offline   Reply With Quote
Old April 2nd, 2020, 10:06   #10
Vince Waldon
Yup, as I understand it pin 4 is a sensor output that ranges linearly between 0.35V (throttle at rest) to 4.5V (pedal to the floor).
WANTED. I need a wiring harness and throttle pedal Jmason59 Private TDI Items for Sale/Wanted 4 March 18th, 2017 09:53
WTB: mk4 ALH throttle pedal assembly vtpsd Private TDI Items for Sale/Wanted 5 August 8th, 2015 11:48
throttle pedal doesnt do anything john hennessy VW B5 Passat TDIs 35 August 12th, 2014 07:02
ALH injection pump wiring info needed. penclnck VW MKIV-A4 TDIs (VE and PD) 3 August 7th, 2011 19:29
Where is the throttle pedal potentiometer? BLAST3 TDI Power Enhancements 11 April 10th, 2007 10:52
Page generated in 0.15897 seconds with 13 queries
[Output: 97.41 Kb. compressed to 82.70 Kb. by saving 14.71 Kb. (15.10%)]
