Old March 30th, 2020, 00:32   #1
Mark buster
TDI(s): AFN
Default How to remove mil lights on cluster
So currently stripped out all unwanted wires from loom bit obviously I have mil lights of ABS,Airbag etc how are these removed?
TIA
Mark
Mark buster is offline   Reply With Quote
Old March 30th, 2020, 08:48   #2
jhax
You need to send them to someone who can tune them out. It's a software thing.
jhax is offline   Reply With Quote
Old March 30th, 2020, 14:22   #3
xerootg
I recently found a tool disable individual codes in edc16 files if your interested in going down the path of doing it yourself, but the consequences of a bad flash are pretty harsh.
Sent from my Pixel 3 using Tapatalk
xerootg is offline   Reply With Quote
Old March 31st, 2020, 10:02   #4
bobbiemartin
Not sure what you are doing, but coding would be the correct way. However, if all you want is not to see the lights and you are not concerned with setting codes, etc. then there is another way. All you need to do is remove the cluster, dismantle enough to get to the lights and place a bit of well cut electrical tape over the lights. If you want you can cut a small piece of foam to fill up the hole but the tape alone works pretty well. I've had several cars with immobilizer delete and that is how I got rid of the light. If you search you can find instructions on how to dismantle the cluster including removing and replacing the needles.
bobbiemartin is offline   Reply With Quote
Old March 31st, 2020, 10:16   #5
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
I didn't know about the codes when I did the swap,so I just removed the wires out of the harness .LOL. Been driving it like that for 2 years.
What is suppose to happen if done that way?
1.9ZOOK is offline   Reply With Quote
No CEL/MIL or Airbag lights on cluster, 98 A3 AHU turbodieseldyke VW MKIII-A3/B4 TDIs 5 September 3rd, 2018 18:45
Jetta 5 2.0TDI beeping instrument cluster and flashing cluster lights. HELP PLEASE!!! B40RK@D VW MKV-A5 Golf/Jettas 9 January 24th, 2016 19:58
MIL Led Cluster Problem ninedee_golf_tdi TDI Conversions 2 December 23rd, 2009 10:35
MIL, reverse, and brake lights? apple4ever VW MKIV-A4 TDIs (VE and PD) 1 October 31st, 2006 05:50
How does the glowplug/Mil lights work dieseling TDI 101 1 October 28th, 2002 19:15
Page generated in 0.12380 seconds with 13 queries
[Output: 67.72 Kb. compressed to 60.02 Kb. by saving 7.70 Kb. (11.37%)]
