POWERSTROKE
On my way home from work when I turned my euro switch to the city light position, none of the lights that I mentioned in the title turned to the on position. I switched it back and forth a couple times. Then finally it worked. All connections behind the switch are tight. This happened one time in the beginning of the winter for a split second. I tried the switch 10 times when I got home, and works fine....What is this about? It's not coolant migration BTW.
