Hi All,
I have a 2000 ALH 1.9 TDI
And cant pass emissions inspection due to the P1619 code.
Since I have replaced and verified the glow plugs themselves.
Wire harness, relay and still no power to the harness even when coolant sensor disconnected.
I am running out of ideas.
Did clear engine after replaced all this but it keeps coming back.
Check engine comes always within 30-40 sec after i start the engine.
Is there any way to pas the emissions test by bypassing the check engine or trick the ECU of thinking signal is high or low?
Any help is Appreciated
BDWY Did check the wiring on the battery as well and cleaned the terminals
Regards
Regards
