Cold Starting Problem
I have an 03 Golf TDI with about 163,000 miles on it. I have had it since new. The intake manifold was cleaned out at about 120,000 miles. In the past year I have had starting problems. If the engine is warm, it starts perfectly regardless of the outside temperature. In warm weather with the engine warm or cold, it starts perfectly.
In cool or cold weather with the engine cold, it doesn't want to start. It turns over on the starter fine, but doesn't fire. If I wait until the glowplug light goes out & immediately turn the key off & back on again & repeat this process several times before turning the key to start, it starts fine in cold weather, i.e at temps below about 30 F. It appears that that the glowplugs aren't staying on long enough & this trick keeps them on long enough to get hot. If the weather is cool, i.e. 35 to 45 F, the trick of cycling the key on & off to keep the glow plugs on longer doesn't seem to help much, & it takes considerable cranking to get it to start.
I assume the engine computer determines how long to heat the glowplugs based on input from an engine temperature sensor. Is this the way the system works? I assume that the glowplugs aren't staying on long enough due to a bad temp sensor or bad connections to the sensor.
I have gone to the VW dealer for this problem several times, & they say they can't find anything wrong with it.
Any suggestions?
