Old September 9th, 2006, 18:39   #1
Westro
Fuel Economy: 48.3 MPG lifetime
Default Crazy Crazy lights and locks - Central Conv?
Where to start.
About a year ago I lost the ability to use both my FOBs. At that time I felt like I had a Central Convience issue as I was unable to re-program my FOBs.
Now I have gremlins... Driving the horn honks. The LED on the driver door stays on, the locks dont work some times and the lights in the cabin are going crazy (sometimes they work and sometimes they just stay on).
So does this confirm that my module is shot? Where is this box and has anyone seen this before?
Here is my VAG scan. The Engine ones I know about, EGR and glow plug I can fix.
VAG-COM Version: Release 311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01 -------------------------------------------------------
Controller: 038 906 012 FD
Component: 1,9l R4 EDC G020SG 4102
Coding: 00002
Shop #: WSC 00066
3VWRP69M92M013841 VWZ7Z0A3837591
2 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 35-10 - - - Intermittent
17056 - Cylinder 2 Glow Plug Circuit (Q11) Electrical Fault
P0672 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066
No fault code found.
Skipping Address 15-Airbags
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56 -------------------------------------------------------
Controller: 1J0 035 180 D
Component: RADIO 3CP 0002
Coding: 02401
Shop #: WSC 00066
End -------------------------------------------------------
2002 Black Jetta TDI manual GL, 308K SOLD
2002 Black Jetta TDI manual GLS, 330K SOLD
2002 Blue Jetta TDI GLS, Auto SOLD
2003 Silver Jetta TDI manual GLS, 125K and a Whole Pile of other Diesels
Westro is offline   Reply With Quote
Old September 9th, 2006, 19:26   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
I've read some about a thing called 'coolant migration', could this
be it??? I really don't know, but it's a place to start!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old September 10th, 2006, 18:46   #3
Westro
Don't think so, I've done the migration modification to the bottle. I wanted to see if others felt like it was the convience module. And frankly where is the module that is giving me trouble?
Old September 11th, 2006, 01:42   #4
Sebastian
Scan your car again, this time do NOT use the MK3 (1H) setting, use 1J (MK4) instead.
Sebastian
Sebastian is offline   Reply With Quote
Old September 11th, 2006, 03:59   #5
Westro
Seems like every day it is a different 'issue'. This morning I had a signal that I had a door open on the cluster but couldn't find door open. About 3 miles down the road the light went off.
I'll re-scan tonight.
Old September 12th, 2006, 08:38   #6
moondawg
moondawg's Avatar
Fuel Economy: Best: 52.33 Worst: about 39 Avg: 48
The switch in your drivers door is bad. I think there is a thread somewhere on a $3 fix for that... .lemme look.
Yup, here it is!
See if that don't fix y'all's problem!
moondawg
PP520 Nozzles, CAT fuel filter, Panzer Plate, Kerma Tranny Mod, Potato Chip, custom canuter valve, low-friction muffler bearings, synthetic turn signal fluid.
moondawg is offline   Reply With Quote
Old September 14th, 2006, 19:01   #7
Westro
OK, I go to re-scan tonight after the wife got home with it. The LED on the driver door is on, no inside lights and the light on the radio is blinking. Locks don't work and I can't open the truck. And when I go to scan it, i can not get any communications. So I disconnect the battery and now I got a scan of it. What to make of all this?
So a bad door switch would cause all this?
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Coding: 00002
Shop #: WSC 00066
Coding: 0004097
Shop #: WSC 00066
Address 17 -------------------------------------------------------
Controller: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V58
Coding: 07232
Shop #: WSC 00000
1 Fault Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
1 Fault Found:
Address 35 -------------------------------------------------------
Controller: 1C0 962 258 AC
Component: 0S Zentr.Verriegel. 0003
Coding: 00018
Shop #: WSC 04097
1 Fault Found:
01044 - Control Module Incorrectly Coded
35-00 - -
Coding: 02401
Shop #: WSC 00066
Old September 18th, 2006, 06:48   #8
Westro
So does anyone have an idea on the 01336?
Old September 18th, 2006, 09:37   #9
owr084
Just a stab in the dark, have you physically looked at the CCM? VW did a bad thing and placed them on the floor where they are susceptible to flooding/water damage...
owr084 is offline   Reply With Quote
Old September 18th, 2006, 09:50   #10
tongsli
35 is for central locks, and I don't see anything for 46. It could be the lock or the CCM at this point, you need to isolate where the problem is occuring.
Right now, it's hard to tell.
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old September 18th, 2006, 09:50   #11
timmyd
I don't know if this applies to the MK4, but those problems in a mk3 would lead me to believe it was a failing ignition switch
2007 4 Door GTI -->Mine
2000 Jetta TDI -->Hers
1998 Jetta GL -->Sold
timmyd is offline   Reply With Quote
Old September 18th, 2006, 12:09   #12
Westro
Please refer to my other post.
http://forums.tdiclub.com/showthread.php?t=152366
This weekend I noticed that I also have a relay in the lower left dash that is clicking. Does anyone have an idea on what the relays under the dash run power too?
So where is the CCM so I can physically check the connections and module.
Old September 19th, 2006, 11:04   #13
dieselgus
dieselgus's Avatar
Double check and reseat all fuses in the fusepanel on the end of the dash. Had a customer's Jetta in here once for a deck. For some reason, turning on the parking lights would also pop the trunk......... pulled and reseated the fuses, found a 15A ATC that was loose (almost falling out) that also happened to be one of the CCM fuses. Reseated, and all strange things stopped.
The other thing would be to check the grounding points in the driver's kickpanel, beside the column, and under the battery tray for tightness/lack of corrosion. A loose ground can do all sorts of interesting things in these cars. This doesn't sound like a failed contoller, rather it sounds like a failed connection or supply line to that controller.
Check the fuses first, then go after the grounds.
Gus
http://www.myspace.com/guslive
'04 Variant 5spd Black/black leather
"The answer is 42....."
dieselgus is offline   Reply With Quote
Page generated in 0.15706 seconds with 10 queries
[Output: 112.96 Kb. compressed to 94.38 Kb. by saving 18.58 Kb. (16.45%)]
