BobnOH
not-a-mechanic
Not really. Perhaps someone knows. You'll need the technical data for each to compare.
Cosmetics is just 1 point, from what I understand 90 hp maf can read until 850 mg/st and 110 hp maf can read until 1250 mg/st.Cosmetics may be indicative of but not a true determination of function.
Even the plug and tube connects can be modified.
The important thing is what they do. I saw some posts over in the Power Enhancement forum where they got into this some.
Good Document
Really good one!Good Document
I'm thinking about the union bolt on the turbo feed. Is it the same inside diameter at all tdi turbos?Pretty sure both the supply and return are unrestricted. Tricky to get on and off without damage.
