JPinnell
I've been fighting an intermittent no start issue for weeks on my 330K 2000 Golf. Symptoms appeared like a weak battery. Turn key on, cluster lights up, glow plugs cycle, turn key to start and clicking with no crank over. Sometimes the cluster would blank out doing this. Repeat a few times and eventually it would start. If not it would start with a jump from another running car.
Current battery was 3 yrs old so I swapped in a new one. Things were fine for a couple weeks, then issues returned intermittently.
Crawled under the dash, verified I had a grey Relay 109. My research here showed that a bad 109 would not cycle the glow plugs so I thought mine was good.
Thought it must be something else. Battery showed 12.8V at rest, 14V charging. Pulled the NEW battery, had it load tested, thinking maybe a bad cell.? Cleaned all the grounds under the battery tray, for the ECU, engine block, starter connection, etc. Thought maybe I had a dead short draining the battery while sitting?
Things were fine for a couple days, then multiple no start, dead cluster, etc. Battery metered 12.8V, but car started with a jump and drove 60miles home.
Said F it and ordered the $20 Relay 109. Swapped it out and the car fired right up.
My thinking is the 109 Relay failed internally. I've had the car 9yrs and almost 250K. Maybe a bad solder joint where it could handle some load, but not enough? Jumping from a running car would be 14V, slightly higher, but just enough to make the gap?
